Flanges
ASME B16.5 - Blind Flanges - 150 lbs -
Blind flanges ASME B16.5
ASME B16.5 - Blind Flanges - 1500 lbs -
ASME B16.5 - Blind Flanges - 2500 lbs -
Blind flanges ASME B16.5 - 2500 lbs
ASME B16.5 - Blind Flanges - 300 lbs -
ASME B16.5 - Blind Flanges - 400 lbs -
Blind flanges ASME B16.5 - 400 lbs
ASME B16.5 - Blind Flanges - 600 lbs -
ASME B16.5 - Blind Flanges - 900 lbs -
ASME B16.5 Slip-on Flanges - 150 lbs -
Slip-on ASME B16.5 FLanges 150 lbs
ASME B16.5 Slip-on Flanges - 1500 lbs -
Slip-on ASME B16.5 FLanges 1500 lbs
ASME B16.5 Slip-on Flanges - 2500 lbs -
Slip-on ASME B16.5 FLanges 2500 lbs
ASME B16.5 Slip-on Flanges - 300 lbs -
Slip-on ASME B16.5 FLanges 300 lbs
ASME B16.5 Slip-on Flanges - 400 lbs -
Slip-on ASME B16.5 FLanges 400 lbs
ASME B16.5 Slip-on Flanges - 600 lbs -
Slip-on ASME B16.5 FLanges 600 lbs
ASME B16.5 Slip-on Flanges - 900 lbs -
ASME B16.5 WN - Welding Neck Flanges - 150 lbs -
Welding Neck ASME B16.5 FLanges 150 lbs
ASME B16.5 WN - Welding Neck Flanges - 1500 lbs -
Welding Neck ASME B16.5 FLanges 1500 lbs
ASME B16.5 WN - Welding Neck Flanges - 2500 lbs -
Welding Neck ASME B16.5 FLanges 2500 lbs
ASME B16.5 WN - Welding Neck Flanges - 300 lbs -
Welding Neck ASME B16.5 FLanges 300 lbs
ASME B16.5 WN - Welding Neck Flanges - 400 lbs -
Welding Neck ASME B16.5 FLanges 400 lbs
ASME B16.5 WN - Welding Neck Flanges - 600 lbs -
Welding Neck ASME B16.5 FLanges 600 lbs
ASME B16.5 WN - Welding Neck Flanges - 900 lbs -
Welding Neck ASME B16.5 FLanges 900 lbs
UNI EN 1092-1 Plane Flanges PN6 -
From EN 1092-1 Flanges and their joints - Circular flanges for pipes, valves, fittings and accessories - PN designated
Edit:
undo -
redo
Color:
change color!
View:
iso -
top -
front -
right -
left -
back -
bottom
Make Component:
Rotate Object(s):
degrees around
red,
green or
blue
move/copy!
no. copies
red
green
blue
with multiple copies.
move!
New! Change Insertion Point
red
green
blue
- Start position
red
green
blue
- End position
insert!
insert!
red (size)
green (size)
blue (vertical position)
insert!
red (horizontal position)
green (size)
blue (vertical size)
insert!
red (size)
green (horizontal position)
Insert Box: - add a box
insert!
red (width)
green (depth)
blue (height)
insert!
name
url
9 11 7
It's FREE and
it's FUN!
Download
engineeringtoolbox.rb
Exit and reload SketchUp!
or
(Mac)
(Mac users look here!)
add components to the
groups!
on Mac computers.
