Sign in!
Home > Piping > Flanges >
ASME B16.5 WN - Welding Neck Flanges - 400 lbs
Welding Neck ASME B16.5 FLanges 400 lbs
welding neck flange 400 lbs
Nominal SizeOutside Diameter of FlangeDiameter BoreThickness of FlangeDiameter of Raised FaceHeight of Raised FaceDiameter of Hub at BaseDiameter of Hub at Point of WeldingLength through HubNo. of HolesDiameter of HolesDiameter of BoltsDiameter of Bolt CircleWeight
ininininininininininininlbs
insert!1/23.750.550.561.380.251.50.842.0640.621/22.622
insert!3/44.620.740.621.690.251.881.052.2540.755/83.254
insert!14.880.960.6920.252.121.322.4440.755/83.54
insert!1 1/45.251.2750.812.50.252.51.662.6240.755/83.886
insert!1 1/26.121.50.882.880.252.751.92.7540.883/44.58
insert!26.51.9413.620.253.312.382.8880.755/8512
insert!2 1/27.52.311.124.120.253.942.883.1280.883/45.8818
insert!38.252.91.2550.254.623.53.2580.883/46.6223
insert!3 1/293.351.385.50.255.2543.38817/87.2526
insert!41041.386.190.255.754.53.5817/87.8835
insert!51151.57.310.2575.564817/89.2543
insert!612.561.628.50.258.126.634.061217/810.6257
insert!81581.8810.620.2510.258.634.62121.1211389
insert!1017.5102.1212.750.2512.6210.754.88161.251 1/815.25125
insert!1220.5122.25150.2514.7512.755.38161.381 1/417.75175
insert!1423132.3816.250.2516.75145.88201.381 1/420.25230
insert!1625.5152.518.50.2519166201.51 3/822.5295
insert!1828172.62210.2521186.5241.51 3/824.75350
insert!2030.5192.75230.2523.12206.62241.621 1/227425
insert!243623327.250.2527.62246.88241.881 3/432620
custom!
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
10 9 3
