Sign in!
Home > Piping > Flanges >
ASME B16.5 Slip-on Flanges - 900 lbs
Slip-on ASME B16.5 FLanges 150 lbs
slip-on flange 900 lbs
Nominal SizeOutside Diameter of FlangeDiameter BoreThickness of FlangeDiameter of Raised FaceHeight of Raised FaceDiameter of Hub at BaseLength through HubNo. of HolesDiameter of HolesDiameter of BoltsDiameter of Bolt CircleWeight
inininininininininininlbs
insert!1/24.750.880.881.380.251.51.2540.883/43.256
insert!3/45.121.0911.690.251.751.3840.883/43.56
insert!15.881.361.1220.252.061.63417/847.5
insert!1 1/46.251.701.122.50.252.51.63417/84.3810
insert!1 1/271.951.252.880.252.751.7541.1214.8814
insert!28.52.441.53.620.254.122.25817/86.522
insert!2 1/29.622.941.624.120.254.882.581.1217.536
insert!39.53.571.550.2552.13817/87.531
insert!411.54.571.756.190.256.252.7581.251 1/89.2553
insert!513.755.6627.310.257.53.1381.381 1/41183
insert!6156.722.198.50.259.253.38121.251 1/812.5108
insert!818.58.722.510.620.2511.754121.51 3/815.5172
insert!1021.510.882.7512.750.2514.54.25161.51 3/818.5245
insert!122412.883.12150.2516.54.63201.51 3/821326
insert!1425.2514.143.3816.250.2517.755.13201.621 1/222380
insert!1627.7516.163.518.50.25205.25201.751 5/824.25459
insert!183118.184210.2522.2562021 7/827647
insert!2033.7520.24.25230.2524.56.25202.12229.5792
insert!244124.255.527.250.2529.58202.622 1/235.51480
custom!
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
10 3 20
