Home  > Piping  > Flanges  >
DIN 2633 Welding Neck Flanges PN16/16BAR
Dimensions, sizes and specifications of DIN 2633 Welding Neck Flanges PN16/16BAR
Nominal Size Outside Diameter of Flange Diameter Bore Thickness of Flange Diameter of Raised Face Height of Raised Face Diameter of Hub at Base Diameter of Hub at Point of Welding Length through Hub No. of Holes Diameter of Holes Diameter of Bolts Diameter of Bolt Circle Weight
mm mm mm mm mm mm mm mm mm mm mm mm kg
insert! 10 90 10.4 14 40 2 25 14 35 4 14 60 0.58
insert! 10 90 13.6 14 40 2 28 17.2 35 4 14 60 0.58
insert! 15 95 16 14 45 2 30 20 35 4 14 65 0.65
insert! 15 95 17.3 14 45 2 32 21.3 35 4 14 65 0.65
insert! 20 105 20.4 16 58 2 38 25 38 4 14 75 0.95
insert! 20 105 22.3 16 58 2 40 26.9 38 4 14 75 0.95
insert! 25 115 24.8 16 68 2 42 30 38 4 14 85 1.15
insert! 25 115 28.5 16 68 2 45 33.7 38 4 14 85 1.14
insert! 32 140 32.8 16 78 2 52 38 40 4 18 100 1.67
insert! 32 140 37.2 16 78 2 56 42.4 40 4 18 100 1.65
insert! 40 150 39.3 16 88 3 60 44.5 42 4 18 110 1.85
insert! 40 150 43.1 16 88 3 64 48.3 42 4 18 110 1.83
insert! 50 165 51.2 18 102 3 72 57 45 4 18 125 2.51
insert! 50 165 54.5 18 102 3 75 60.3 45 4 18 125 2.48
insert! 65 185 70.3 18 122 3 90 76.1 45 4 18 145 3.03
insert! 80 200 82.5 20 138 3 105 88.9 50 8 18 160 3.82
insert! 100 220 100.8 20 158 3 125 108 52 8 18 180 4.54
insert! 100 220 107.1 20 158 3 131 114.3 52 8 18 180 4.41
insert! 125 250 125 22 188 3 150 133 55 8 18 210 6.28
insert! 125 250 131.7 22 188 3 156 139.7 55 8 18 210 6.07
insert! 150 285 150 22 212 3 175 159 55 8 22 240 7.75
insert! 150 285 159.3 22 212 3 184 168.3 55 8 22 240 7.4
insert! 175 315 182.9 24 242 3 210 193.7 60 8 22 270 9.86
insert! 200 340 207.3 24 268 3 235 219.1 62 12 22 295 10.85
insert! 250 405 254.4 26 320 3 285 267 70 12 26 355 16.26
insert! 250 405 260.4 26 320 3 292 273 70 12 26 355 15.87
insert! 300 460 309.7 28 378 4 344 323.9 78 12 26 410 21.24
insert! 350 520 339.6 30 438 4 390 355.6 82 16 26 470 31.38
insert! 350 520 352 30 438 4 390 368 82 16 26 470 28.95
insert! 400 580 390.4 32 490 4 445 406.4 85 16 30 525 39.3
insert! 400 580 403 32 490 4 445 419 85 16 30 525 36.3
insert! 500 715 492 34 610 4 548 508 90 20 33 650 59.63
insert! 600 840 592.4 36 725 5 652 610 95 20 36 770 82.54
insert! 700 910 693.4 36 795 5 755 711 100 24 36 840 83.9
insert! 800 1025 793 38 900 5 855 813 105 24 39 950 107.3
insert! 900 1125 894 40 1000 5 955 914 110 28 39 1050 124.97
insert! 1000 1255 996 42 1115 5 1058 1016 120 28 42 1170 163.76
insert! 1200 1485 1195 48 1330 5 1262 1220 130 32 48 1390 244.15
insert! 1400 1685 1391.6 52 1530 5 1465 1420 145 36 48 1590 320.87
insert! 1600 1930 1588 58 1750 5 1668 1620 160 40 56 1820 465.83
insert! 1800 2130 1785 62 1950 5 1870 1820 170 44 56 2020 570.52
insert! 2000 2345 1980 66 2150 5 2072 2020 180 48 62 2230 706.74
custom!
Length
Color
Offset
ISO and DIN dimensions.
Tip! - use the "Rotate Object" bellow to turn the object after it is inserted.
Edit
undo! - redo!
Color
View
Make Component
Rotate Object(s)
Move or Copy Object(s)
The Knife
YouTube demo of the Knife!
Change Insertion Point
Insert Line
red green blue - End position
Insert Horizontal Plane
Insert Vertical Plane
Insert Box
Insert external Component
insert! name url
