Home  > Piping  > Flanges  >
DIN 2638 Welding Neck Flanges PN160/160BAR
Dimensions, sizes and specifications of DIN 2638 Welding Neck Flanges PN160/160BAR
Nominal Size Outside Diameter of Flange Diameter Bore Thickness of Flange Diameter of Raised Face Height of Raised Face Diameter of Hub at Base Diameter of Hub at Point of Welding Length through Hub No. of Holes Diameter of Holes Diameter of Bolts Diameter of Bolt Circle Weight
mm mm mm mm mm mm mm mm mm mm mm mm kg
insert! 10 100 10 20 40 2 28 14 45 4 14 70 1.08
insert! 10 100 13.2 20 40 2 32 17.2 45 4 14 70 1.08
insert! 15 105 16 20 45 2 32 20 45 4 14 75 1.19
insert! 15 105 17.3 20 45 2 34 21.3 45 4 14 75 1.19
insert! 25 140 24.2 24 68 2 48 30 58 4 18 100 2.62
insert! 25 140 27.9 24 68 2 52 33.7 58 4 18 100 2.62
insert! 40 170 37.3 28 88 3 65 44.5 64 4 22 125 4.36
insert! 40 170 41.1 28 88 3 70 48.3 64 4 22 125 4.34
insert! 50 195 49 30 102 3 86 57 75 4 26 145 6.28
insert! 50 195 52.3 30 102 3 90 60.3 75 4 26 145 6.27
insert! 65 220 66.1 34 122 3 108 76.1 82 8 26 170 8.61
insert! 80 230 76.3 36 138 3 120 88.9 86 8 26 180 10.09
insert! 100 265 92 40 162 3 145 108 100 8 30 210 15.28
insert! 100 265 98.3 40 162 3 150 114.3 100 8 30 210 15.07
insert! 125 315 113 44 188 3 180 133 115 8 33 250 24.68
insert! 125 315 119.7 44 188 3 180 139.7 115 8 33 250 24.09
insert! 150 355 134 50 218 3 210 159 128 12 33 290 35.14
insert! 150 355 143.3 50 218 3 210 168.3 128 12 33 290 34.02
insert! 175 390 165.3 54 260 3 245 193.7 138 12 36 320 44.9
insert! 200 490 187.1 60 285 3 278 219.1 140 12 36 360 60.03
insert! 250 515 227 68 345 3 340 267 155 12 42 430 98.05
insert! 250 515 233 68 345 3 340 273 155 12 42 430 96.52
insert! 300 585 279.5 76 410 4 400 323.9 175 16 42 500 138.8
custom!
Length
Color
Offset
ISO and DIN dimensions.
Edit
undo! - redo!
Color
View
Make Component
Rotate Object(s)
Move or Copy Object(s)
The Knife
YouTube demo of the Knife!
Change Insertion Point
Insert Line
red green blue - End position
Insert Horizontal Plane
Insert Vertical Plane
Insert Box
Insert external Component
insert! name url
