Sign in!
Home > Piping > Flanges >
ASME B16.5 WN - Welding Neck Flanges - 300 lbs
Welding Neck ASME B16.5 FLanges 300 lbs
welding neck flange 300 lbs
Nominal SizeOutside Diameter of FlangeDiameter BoreThickness of FlangeDiameter of Raised FaceHeight of Raised FaceDiameter of Hub at BaseDiameter of Hub at Point of WeldingLength through HubNo. of HolesDiameter of HolesDiameter of BoltsDiameter of Bolt CircleWeight
ininininininininininininlbs
insert!1/23.750.50.561.380.06251.50.842.0640.621/22.622
insert!3/44.620.750.621.690.06251.881.052.2540.755/83.253
insert!14.8810.6920.06252.121.322.4440.755/83.54
insert!1 1/45.251.250.752.50.06252.51.662.5640.755/83.885
insert!1 1/26.121.50.812.880.06252.751.92.6940.883/44.57
insert!26.520.883.620.06253.312.382.7580.755/859
insert!2 1/27.52.514.120.06253.942.88380.883/45.8812
insert!38.2531.1250.06254.623.53.1280.883/46.6215
insert!3 1/293.51.195.50.06255.2543.1980.883/47.2518
insert!41041.256.190.06255.754.53.3880.883/47.8825
insert!51151.387.310.062575.563.8880.883/49.2532
insert!612.561.448.50.06258.126.633.88120.883/410.6242
insert!81581.6210.620.062510.258.634.381217/81367
insert!1017.5101.8812.750.062512.6210.754.62161.12115.2591
insert!1220.5122150.062514.7512.755.12161.251 1/817.75140
insert!1423132.1216.250.062516.75145.62201.251 1/820.25180
insert!1625.5152.2518.50.062519165.75201.381 1/422.5250
insert!1828172.38210.062521186.25241.381 1/424.75320
insert!2030.5192.5230.062523.12206.38241.381 1/427400
insert!2436232.7527.250.062527.62246.62241.621 1/232580
custom!
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
9 11 22
