Dimension and weight of DIN 2576 Plate Flanges PN10
NB! If there is problem with inserting flanges - try to reinstall the extension by using alternative 3 as described in the right column.
Nominal Size | Outside Diameter of Flange | Diameter Bore | Thickness of Flange | No. of Holes | Diameter of Holes | Diameter of Bolts | Diameter of Bolt Circle | Weight | |
mm | mm | mm | mm | mm | mm | mm | kg | ||
insert! | 10 | 90 | 14.5 | 14 | 4 | 14 | 60 | 0.61 | |
insert! | 10 | 90 | 17.7 | 14 | 4 | 14 | 60 | 0.6 | |
insert! | 15 | 95 | 21 | 14 | 4 | 14 | 65 | 0.67 | |
insert! | 15 | 95 | 22 | 14 | 4 | 14 | 65 | 0.67 | |
insert! | 20 | 105 | 26 | 16 | 4 | 14 | 75 | 0.94 | |
insert! | 20 | 105 | 27.6 | 16 | 4 | 14 | 75 | 0.94 | |
insert! | 25 | 115 | 31 | 16 | 4 | 14 | 85 | 1.13 | |
insert! | 25 | 115 | 34.4 | 16 | 4 | 14 | 85 | 1.11 | |
insert! | 32 | 140 | 39 | 16 | 4 | 18 | 100 | 1.66 | |
insert! | 32 | 140 | 43.1 | 16 | 4 | 18 | 100 | 1.62 | |
insert! | 40 | 150 | 45.5 | 16 | 4 | 18 | 110 | 1.89 | |
insert! | 40 | 150 | 49 | 16 | 4 | 18 | 110 | 1.85 | |
insert! | 50 | 165 | 58.1 | 18 | 4 | 18 | 125 | 2.5 | |
insert! | 50 | 165 | 61.1 | 18 | 4 | 18 | 125 | 2.46 | |
insert! | 65 | 185 | 77.1 | 18 | 4 | 18 | 145 | 2.99 | |
insert! | 80 | 200 | 90.3 | 20 | 8 | 18 | 160 | 3.61 | |
insert! | 100 | 220 | 109.6 | 20 | 8 | 18 | 180 | 4.17 | |
insert! | 100 | 220 | 115.9 | 20 | 8 | 18 | 180 | 3.99 | |
insert! | 125 | 250 | 134.8 | 22 | 8 | 18 | 210 | 5.66 | |
insert! | 125 | 250 | 141.6 | 22 | 8 | 18 | 210 | 5.41 | |
insert! | 150 | 285 | 161.1 | 22 | 8 | 22 | 240 | 6.97 | |
insert! | 150 | 285 | 170.5 | 22 | 8 | 22 | 240 | 6.55 | |
insert! | 175 | 315 | 196.1 | 24 | 8 | 22 | 270 | 8.42 | |
insert! | 200 | 340 | 221.8 | 24 | 8 | 22 | 295 | 9.28 | |
insert! | 250 | 395 | 270.2 | 26 | 12 | 22 | 350 | 12.36 | |
insert! | 250 | 395 | 276.2 | 26 | 12 | 22 | 350 | 11.85 | |
insert! | 300 | 445 | 327.6 | 26 | 12 | 22 | 400 | 13.61 | |
insert! | 350 | 505 | 359.7 | 28 | 16 | 22 | 460 | 20.35 | |
insert! | 350 | 505 | 372.2 | 28 | 16 | 22 | 460 | 18.77 | |
insert! | 400 | 565 | 411 | 32 | 18 | 26 | 515 | 27.52 | |
insert! | 400 | 565 | 423.7 | 32 | 18 | 26 | 515 | 35.43 | |
insert! | 450 | 615 | 462.3 | 38 | 20 | 26 | 565 | 35.11 | |
insert! | 500 | 670 | 513.6 | 38 | 20 | 26 | 620 | 40.2 | |
insert! | 600 | 780 | 615.5 | 40 | 20 | 26 | 725 | 51.87 | |
custom! |
ISO Series 1 and DIN Series 2
Tip! - use the "Rotate Object" bellow to turn the object after it is inserted.
undo! redo!
change color!
make!
startpoint
endpoint insert!
It's FREE and FUN!
and more.
3 18
