Sign in!
Home > Piping > Flanges >
ASME B16.5 Slip-on Flanges - 1500 lbs
Slip-on ASME B16.5 FLanges 1500 lbs
slip-on flange 1500 lbs
Nominal SizeOutside Diameter of FlangeDiameter BoreThickness of FlangeDiameter of Raised FaceHeight of Raised FaceDiameter of Hub at BaseLength through HubNo. of HolesDiameter of HolesDiameter of BoltsDiameter of Bolt CircleWeight
inininininininininininlbs
insert!1/24.750.880.881.380.251.51.2540.883/43.256
insert!3/45.121.0911.690.251.751.3840.883/43.56
insert!15.881.361.1220.252.061.63417/847.5
insert!1 1/46.251.701.122.50.252.51.63417/84.3810
insert!1 1/271.951.252.880.252.751.7541.1214.8814
insert!28.52.441.53.620.254.122.25817/86.522
insert!2 1/29.622.941.624.120.254.882.581.1217.536
insert!310.53.571.8850.255.252.8881.251 1/8848
insert!412.254.572.126.190.256.383.5681.381 1/49.573
insert!514.755.662.887.310.257.754.1381.621 1/211.5132
insert!615.56.723.258.50.2594.69121.51 3/812.5164
insert!8198.723.6210.620.2511.55.63121.751 5/815.5258
insert!102310.884.2512.750.2514.56.251221 7/819436
insert!1226.512.884.88150.2517.757.13162.12222.5667
custom!
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
10 3 21
