Sign in!
Home > Piping > Flanges >
ASME B16.5 Slip-on Flanges - 400 lbs
Slip-on ASME B16.5 FLanges 400 lbs
slip-on flange 400 lbs
Nominal SizeOutside Diameter of FlangeDiameter BoreThickness of FlangeDiameter of Raised FaceHeight of Raised FaceDiameter of Hub at BaseLength through HubNo. of HolesDiameter of HolesDiameter of BoltsDiameter of Bolt CircleWeight
inininininininininininlbs
insert!1/23.750.880.561.380.251.50.8840.621/22.622
insert!3/44.621.090.621.690.251.88140.755/83.253
insert!14.881.360.6920.252.121.0640.755/83.53.5
insert!1 1/45.251.70.812.50.252.51.1240.755/83.884.5
insert!1 1/26.121.950.882.880.252.751.2540.883/44.56.5
insert!26.52.4413.620.253.311.4480.755/858
insert!2 1/27.52.941.124.120.253.941.6280.883/45.8812
insert!38.253.571.2550.254.621.8180.883/46.6215
insert!3 1/294.071.385.50.255.251.94817/87.2521
insert!4104.571.386.190.255.752817/87.8824
insert!5115.661.57.310.2572.12817/89.2531
insert!612.56.721.628.50.258.122.251217/810.6239
insert!8158.721.8810.620.2510.252.69121.1211363
insert!1017.510.882.1212.750.2512.622.88161.251 1/815.2591
insert!1220.512.882.25150.2514.753.12161.381 1/417.75129
insert!142314.142.3816.250.2516.753.31201.381 1/420.25191
insert!1625.516.162.518.50.25193.69201.51 3/822.5253
insert!182818.182.62210.25213.88241.51 3/824.75310
insert!2030.520.22.75230.2523.124241.621 1/227378
insert!243624.25327.250.2527.624.5241.881 3/432539
custom!
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
9 11 22
