Sign in!
Home > Piping > Flanges >
ASME B16.5 WN - Welding Neck Flanges - 600 lbs
Welding Neck ASME B16.5 FLanges 600 lbs
welding neck flange 600 lbs
Nominal SizeOutside Diameter of FlangeDiameter BoreThickness of FlangeDiameter of Raised FaceHeight of Raised FaceDiameter of Hub at BaseDiameter of Hub at Point of WeldingLength through HubNo. of HolesDiameter of HolesDiameter of BoltsDiameter of Bolt CircleWeight
ininininininininininininlbs
insert!1/23.750.550.561.380.251.50.842.0640.621/22.622
insert!3/44.620.740.621.690.251.881.052.2540.755/83.254
insert!14.880.960.6920.252.121.322.4440.755/83.54
insert!1 1/45.251.2750.812.50.252.51.662.6240.755/83.886
insert!1 1/26.121.50.882.880.252.751.92.7540.883/44.58
insert!26.51.9413.620.253.312.382.8880.755/8512
insert!2 1/27.52.311.124.120.253.942.883.1280.883/45.8818
insert!38.252.91.2550.254.623.53.2580.883/46.6223
insert!3 1/293.351.385.50.255.2543.38817/87.2526
insert!410.753.831.56.190.2564.54817/88.542
insert!5134.811.757.310.257.445.564.581.12110.568
insert!6145.751.888.50.258.756.634.62121.12111.581
insert!816.57.632.1910.620.2510.758.635.25121.251 1/813.75120
insert!10209.752.512.750.2513.510.756161.381 1/417190
insert!122211.752.62150.2515.7512.756.12201.381 1/419.25225
insert!1423.75132.7516.250.2517146.5201.51 3/820.75280
insert!162715318.50.2519.5167201.621 1/223.75390
insert!1829.25173.25210.2521.5187.25201.751 5/825.75475
insert!2032193.5230.2524207.5241.751 5/828.5590
insert!243723427.250.2528.252482421 7/833830
custom!
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
9 11 22
