Home  > Piping  > Flanges  >
AS 2129 Table D - Blind Flanges with Flat Faces
Australien AS 2129 Table D blind flanges with flat faces
AS 2129 Blind flange flat face
Nominal Size Outside Diameter of Flange Thickness of Flange No. of Holes Diameter of Holes Diameter of Bolts Diameter of Bolt Circle Weight
mm mm mm mm mm mm kg
insert! 15 95 5 4 14 M12 67 0.3
insert! 20 100 5 4 14 M12 73 0.3
insert! 25 115 5 4 14 M12 83 0.4
insert! 32 120 6 4 14 M12 87 0.5
insert! 40 135 6 4 14 M12 98 0.6
insert! 50 150 8 4 18 M16 114 0.9
insert! 65 165 8 4 18 M16 127 1.1
insert! 80 185 10 4 18 M16 146 1.6
insert! 100 215 10 4 18 M16 178 2.1
insert! 125 255 13 8 18 M16 210 3.7
insert! 150 280 13 8 18 M16 235 4.1
insert! 200 335 13 8 18 M16 292 5.1
insert! 250 405 16 8 22 M20 356 8.8
insert! 300 455 19 12 22 M20 406 11.9
insert! 350 525 22 12 22 M20 470 20.2
insert! 400 580 22 12 26 M24 521 23.1
insert! 450 640 25 12 26 M24 584 30.7
insert! 500 705 29 16 26 M24 641 42.4
insert! 600 825 32 16 30 M27 756 60.2
custom!
Length
Color
Offset
Tip! - use the "Rotate Object" bellow to turn the object after it is inserted.
Edit
undo! - redo!
Color
View
Make Component
Rotate Object(s)
Move or Copy Object(s)
The Knife
YouTube demo of the Knife!
Change Insertion Point
Insert Line
red green blue - End position
Insert Horizontal Plane
Insert Vertical Plane
Insert Box
Insert external Component
insert! name url
