Sign in!
Home > Piping > Flanges >
ASME B16.5 Slip-on Flanges - 150 lbs
Slip-on ASME B16.5 FLanges 150 lbs
slip-on flange 150 lbs
Nominal SizeOutside Diameter of FlangeDiameter BoreThickness of FlangeDiameter of Raised FaceHeight of Raised FaceDiameter of Hub at BaseLength through HubNo. of HolesDiameter of HolesDiameter of BoltsDiameter of Bolt Circle
ininininininininininin
insert!1/23.50.880.441.380.06251.190.6240.621/22.38
insert!3/43.881.090.51.690.06251.50.6240.621/22.75
insert!14.251.360.562.00.06251.940.6940.621/23.12
insert!1 1/44.621.700.622.50.06252.310.8140.621/23.5
insert!1 1/251.950.692.880.06252.560.8840.621/23.88
insert!262.440.753.620.06253.06140.755/84.75
insert!2 1/272.940.884.120.06253.561.1240.755/85.5
insert!37.53.570.9450.06254.251.1940.755/86
insert!3 1/28.54.070.945.50.06254.811.2580.755/87
insert!494.570.946.190.06255.311.3180.755/87.5
insert!5105.660.947.310.06256.441.4480.883/48.5
insert!6116.7218.50.06257.561.5680.883/49.5
insert!813.58.721.1210.620.06259.691.7580.883/411.75
insert!101610.881.1912.750.0625121.941217/814.25
insert!121912.881.25150.062514.382.191217/817
insert!142114.141.3816.250.062515.752.25121.12118.75
insert!1623.516.161.4418.50.0625182.5161.12121.25
insert!182518.181.56210.062519.882.69161.251 1/822.75
insert!2027.520.21.69230.0625222.88201.251 1/825
insert!243224.251.8827.250.062526.123.25201.381 1/429.5
custom!
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
10 9 3
