Welding Neck ASME B16.5 FLanges 150 lbs
| Nominal Size | Outside Diameter of Flange | Diameter Bore | Thickness of Flange | Diameter of Raised Face | Height of Raised Face | Diameter of Hub at Base | Diameter of Hub at Point of Welding | Length through Hub | No. of Holes | Diameter of Holes | Diameter of Bolts | Diameter of Bolt Circle | Weight | |
| in | in | in | in | in | in | in | in | in | in | in | in | lbs | ||
| insert! | 1/2 | 3.5 | 0.5 | 0.44 | 1.38 | 0.0625 | 1.19 | 0.84 | 1.88 | 4 | 0.62 | 1/2 | 2.38 | 2 |
| insert! | 3/4 | 3.88 | 0.75 | 0.5 | 1.69 | 0.0625 | 1.5 | 1.05 | 2.06 | 4 | 0.62 | 1/2 | 2.75 | 2 |
| insert! | 1 | 4.25 | 1 | 0.56 | 2.0 | 0.0625 | 1.94 | 1.32 | 2.19 | 4 | 0.62 | 1/2 | 3.12 | 3 |
| insert! | 1 1/4 | 4.62 | 1.25 | 0.62 | 2.5 | 0.0625 | 2.31 | 1.66 | 2.25 | 4 | 0.62 | 1/2 | 3.5 | 3 |
| insert! | 1 1/2 | 5 | 1.5 | 0.69 | 2.88 | 0.0625 | 2.56 | 1.9 | 2.44 | 4 | 0.62 | 1/2 | 3.88 | 4 |
| insert! | 2 | 6 | 2 | 0.75 | 3.62 | 0.0625 | 3.06 | 2.38 | 2.5 | 4 | 0.75 | 5/8 | 4.75 | 6 |
| insert! | 2 1/2 | 7 | 2.5 | 0.88 | 4.12 | 0.0625 | 3.56 | 2.88 | 2.75 | 4 | 0.75 | 5/8 | 5.5 | 8 |
| insert! | 3 | 7.5 | 3 | 0.94 | 5 | 0.0625 | 4.25 | 3.5 | 2.75 | 4 | 0.75 | 5/8 | 6 | 10 |
| insert! | 3 1/2 | 8.5 | 3.5 | 0.94 | 5.5 | 0.0625 | 4.81 | 4 | 2.81 | 8 | 0.75 | 5/8 | 7 | 12 |
| insert! | 4 | 9 | 4 | 0.94 | 6.19 | 0.0625 | 5.31 | 4.5 | 3 | 8 | 0.75 | 5/8 | 7.5 | 15 |
| insert! | 5 | 10 | 5 | 0.94 | 7.31 | 0.0625 | 6.44 | 5.56 | 3.5 | 8 | 0.88 | 3/4 | 8.5 | 19 |
| insert! | 6 | 11 | 6 | 1 | 8.5 | 0.0625 | 7.56 | 6.63 | 3.5 | 8 | 0.88 | 3/4 | 9.5 | 24 |
| insert! | 8 | 13.5 | 8 | 1.12 | 10.62 | 0.0625 | 9.69 | 8.63 | 4 | 8 | 0.88 | 3/4 | 11.75 | 39 |
| insert! | 10 | 16 | 10 | 1.19 | 12.75 | 0.0625 | 12 | 10.75 | 4 | 12 | 1 | 7/8 | 14.25 | 52 |
| insert! | 12 | 19 | 12 | 1.25 | 15 | 0.0625 | 14.38 | 12.75 | 4.5 | 12 | 1 | 7/8 | 17 | 80 |
| insert! | 14 | 21 | 13 | 1.38 | 16.25 | 0.0625 | 15.75 | 14 | 5 | 12 | 1.12 | 1 | 18.75 | 110 |
| insert! | 16 | 23.5 | 15 | 1.44 | 18.5 | 0.0625 | 18 | 16 | 5 | 16 | 1.12 | 1 | 21.25 | 140 |
| insert! | 18 | 25 | 17 | 1.56 | 21 | 0.0625 | 19.88 | 18 | 5.5 | 16 | 1.25 | 1 1/8 | 22.75 | 150 |
| insert! | 20 | 27.5 | 19 | 1.69 | 23 | 0.0625 | 22 | 20 | 5.69 | 20 | 1.25 | 1 1/8 | 25 | 180 |
| insert! | 24 | 32 | 23 | 1.88 | 27.25 | 0.0625 | 26.12 | 24 | 6 | 20 | 1.38 | 1 1/4 | 29.5 | 260 |
| custom! | ||||||||||||||
Edit:
undo -
redo
Color:
change color!
View:
iso -
top -
front -
right -
left -
back -
bottom
Make Component:
Rotate Object(s):
degrees around
red,
green or
blue
move/copy!
no. copies
red
green
blue
with multiple copies.
move!
New! Change Insertion Point
red
green
blue
- Start position
red
green
blue
- End position
insert!
insert!
red (size)
green (size)
blue (vertical position)
insert!
red (horizontal position)
green (size)
blue (vertical size)
insert!
red (size)
green (horizontal position)
Insert Box: - add a box
insert!
red (width)
green (depth)
blue (height)
insert!
name
url
10 9 3
It's FREE and
it's FUN!
Download
engineeringtoolbox.rb
Exit and reload SketchUp!
or
(Mac)
(Mac users look here!)
add components to the
groups!
on Mac computers.
