Welding Neck ASME B16.5 FLanges 2500 lbs
| Nominal Size | Outside Diameter of Flange | Diameter Bore | Thickness of Flange | Diameter of Raised Face | Height of Raised Face | Diameter of Hub at Base | Diameter of Hub at Point of Welding | Length through Hub | No. of Holes | Diameter of Holes | Diameter of Bolts | Diameter of Bolt Circle | Weight | |
| in | in | in | in | in | in | in | in | in | in | in | in | lbs | ||
| insert! | 1/2 | 5.25 | 0.55 | 1.19 | 1.38 | 0.25 | 1.69 | 0.84 | 2.88 | 4 | 0.88 | 3/4 | 3.5 | 7 |
| insert! | 3/4 | 5.5 | 0.74 | 1.25 | 1.69 | 0.25 | 2 | 1.05 | 3.12 | 4 | 0.88 | 3/4 | 3.75 | 8 |
| insert! | 1 | 6.25 | 0.96 | 1.38 | 2 | 0.25 | 2.25 | 1.32 | 3.5 | 4 | 1 | 7/8 | 4.25 | 12 |
| insert! | 1 1/4 | 7.25 | 1.28 | 1.5 | 2.5 | 0.25 | 2.88 | 1.66 | 3.75 | 4 | 1.12 | 1 | 5.12 | 17 |
| insert! | 1 1/2 | 8 | 1.5 | 1.75 | 2.88 | 0.25 | 3.12 | 1.9 | 4.38 | 4 | 1.25 | 1 1/8 | 5.75 | 25 |
| insert! | 2 | 9.25 | 1.94 | 2 | 3.62 | 0.25 | 3.75 | 2.38 | 5 | 8 | 1.12 | 1 | 6.75 | 42 |
| insert! | 2 1/2 | 10.5 | 2.31 | 2.25 | 4.12 | 0.25 | 4.5 | 2.88 | 5.62 | 8 | 1.25 | 1 1/8 | 7.75 | 52 |
| insert! | 3 | 12 | 2.9 | 2.62 | 5 | 0.25 | 5.25 | 3.5 | 6.62 | 8 | 1.38 | 1 1/4 | 9 | 94 |
| insert! | 4 | 14 | 3.83 | 3 | 6.19 | 0.25 | 6.5 | 4.5 | 7.5 | 8 | 1.62 | 1 1/2 | 10.75 | 145 |
| insert! | 5 | 16.5 | 4.81 | 3.62 | 7.31 | 0.25 | 8 | 5.56 | 9 | 8 | 1.88 | 1 3/4 | 12.75 | 245 |
| insert! | 6 | 19 | 5.75 | 4.25 | 8.5 | 0.25 | 9.25 | 6.63 | 10.75 | 8 | 2.12 | 2 | 14.5 | 380 |
| insert! | 8 | 21.75 | 7.63 | 5 | 10.62 | 0.25 | 12 | 8.63 | 12.5 | 12 | 2.12 | 2 | 17.25 | 580 |
| insert! | 10 | 26.5 | 9.75 | 6.5 | 12.75 | 0.25 | 14.75 | 10.75 | 16.5 | 12 | 2.62 | 2 1/2 | 21.25 | 1075 |
| insert! | 12 | 30 | 11.75 | 7.25 | 15 | 0.25 | 17.38 | 12.75 | 18.25 | 12 | 2.88 | 2 3/4 | 24.38 | 1525 |
| custom! | ||||||||||||||
Edit:
undo -
redo
Color:
change color!
View:
iso -
top -
front -
right -
left -
back -
bottom
Make Component:
Rotate Object(s):
degrees around
red,
green or
blue
move/copy!
no. copies
red
green
blue
with multiple copies.
move!
New! Change Insertion Point
red
green
blue
- Start position
red
green
blue
- End position
insert!
insert!
red (size)
green (size)
blue (vertical position)
insert!
red (horizontal position)
green (size)
blue (vertical size)
insert!
red (size)
green (horizontal position)
Insert Box: - add a box
insert!
red (width)
green (depth)
blue (height)
insert!
name
url
10 9 3
It's FREE and
it's FUN!
Download
engineeringtoolbox.rb
Exit and reload SketchUp!
or
(Mac)
(Mac users look here!)
add components to the
groups!
on Mac computers.
