Home  > Piping  > Flanges  >
DIN 2636 Welding Neck Flanges PN64/64BAR
Dimensions, sizes and specifications of DIN 2636 Welding Neck Flanges PN64/64BAR
Nominal Size Outside Diameter of Flange Diameter Bore Thickness of Flange Diameter of Raised Face Height of Raised Face Diameter of Hub at Base Diameter of Hub at Point of Welding Length through Hub No. of Holes Diameter of Holes Diameter of Bolts Diameter of Bolt Circle Weight
mm mm mm mm mm mm mm mm mm mm mm mm kg
insert! 10 100 10.4 20 40 2 28 14 45 4 14 70 1.07
insert! 10 100 13.6 20 40 2 32 17.2 45 4 14 70 1.08
insert! 15 105 16 20 45 2 32 20 45 4 14 75 1.19
insert! 15 105 17.3 20 45 2 34 21.3 45 4 14 75 1.19
insert! 25 140 24.8 24 68 2 48 30 58 4 18 100 2.61
insert! 25 140 28.5 24 68 2 52 33.7 58 4 18 100 2.6
insert! 40 170 38.7 26 88 3 65 44.5 62 4 22 125 4
insert! 40 170 42.5 26 88 3 70 48.3 62 4 22 125 3.99
insert! 50 180 51.2 26 102 3 78 57 62 4 22 135 4.45
insert! 50 180 54.5 26 102 3 82 60.3 62 4 22 135 4.42
insert! 65 205 69.7 26 122 3 98 76.1 66 8 22 160 5.49
insert! 80 215 81.7 28 138 3 112 88.9 72 8 22 170 6.5
insert! 100 250 100 30 162 3 132 108 76 8 26 200 9.25
insert! 100 250 106.3 30 162 3 138 114.3 76 8 26 200 9.06
insert! 125 295 124 34 188 3 162 133 88 8 30 240 14.53
insert! 125 295 130.7 34 188 3 168 139.7 88 8 30 240 14.23
insert! 150 345 147.8 36 218 3 192 159 95 8 33 280 21.35
insert! 150 345 157.1 36 218 3 202 168.3 95 8 33 280 20.92
insert! 175 375 181.1 40 260 3 228 193.7 105 12 33 310 26.28
insert! 200 415 204.9 42 285 3 256 219.1 110 12 36 345 33.56
insert! 250 470 249.4 46 345 3 310 267 125 12 36 400 47.98
insert! 250 470 255.4 46 345 3 316 273 125 12 36 400 47.32
insert! 300 530 301.9 52 410 4 372 323.9 140 16 36 460 66.44
insert! 350 600 330.6 56 465 4 420 355.6 150 16 39 525 96.23
insert! 350 600 343 56 465 4 420 368 150 16 39 525 91.77
insert! 400 670 378 60 535 4 475 406.4 160 16 42 585 127.7
insert! 400 670 390.6 60 535 4 475 419 160 16 42 585 122.13
insert! 350 580 338 46 465 4 408 355.6 125 16 36 510 67.73
insert! 350 580 350.4 46 465 4 408 368 125 16 36 510 63.96
insert! 400 660 384.4 50 535 4 462 406.4 135 16 39 585 96.73
insert! 400 660 397 50 535 4 462 419 135 16 39 585 91.99
custom!
Length
Color
Offset
ISO and DIN dimensions.
Edit
undo! - redo!
Color
View
Make Component
Rotate Object(s)
Move or Copy Object(s)
The Knife
YouTube demo of the Knife!
Change Insertion Point
Insert Line
red green blue - End position
Insert Horizontal Plane
Insert Vertical Plane
Insert Box
Insert external Component
insert! name url
