Home  > Piping  > Flanges  >
DIN 2630 Welding Neck Flanges PN2.5/2.5BAR
Dimensions, sizes and specifications of DIN 2630 Welding Neck Flanges PN2.5/2.5BAR
Nominal Size Outside Diameter of Flange Diameter Bore Thickness of Flange Diameter of Raised Face Height of Raised Face Diameter of Hub at Base Diameter of Hub at Point of Welding Length through Hub No. of Holes Diameter of Holes Diameter of Bolts Diameter of Bolt Circle Weight
mm mm mm mm mm mm mm mm mm mm mm mm kg
insert! 20 90 20.4 14 50 2 35 25 32 4 11 65 0.6
insert! 20 90 22.3 14 50 2 38 26.9 32 4 11 65 0.6
insert! 25 100 24.8 14 60 2 40 30 35 4 11 75 0.78
insert! 25 100 28.5 14 60 2 42 33.7 35 4 11 75 0.78
insert! 32 120 32.8 14 70 2 50 38 35 4 14 90 1.07
insert! 32 120 37.2 14 70 2 55 42.4 35 4 14 90 1.06
insert! 40 130 39.3 14 80 3 55 44.5 38 4 14 100 1.21
insert! 40 130 43.1 14 80 3 62 48.3 38 4 14 100 1.2
insert! 50 140 51.2 14 90 3 70 57 38 4 14 110 1.37
insert! 50 140 54.5 14 90 3 74 60.3 38 4 14 110 1.36
insert! 65 160 70.3 14 110 3 88 76.1 38 4 14 130 1.6
insert! 80 190 82.5 16 128 3 102 88.9 42 4 18 150 2.72
insert! 100 210 98.8 16 148 3 122 106 45 4 18 170 3.2
insert! 100 210 107.1 16 148 3 130 114.3 45 4 18 170 3.22
insert! 125 240 125 18 178 3 148 133 48 8 18 200 4.58
insert! 125 240 131.7 18 178 3 155 139.7 48 8 18 200 4.42
insert! 150 265 150 18 202 3 172 159 48 8 18 225 5.26
insert! 150 265 157.3 18 202 3 184 166.3 48 8 18 225 5.04
insert! 200 320 207.3 20 258 3 236 219.1 55 8 18 280 7.95
insert! 250 375 254.4 22 312 3 282 267 60 12 18 335 11.16
insert! 250 375 260.4 22 312 3 290 273 60 12 18 335 10.57
insert! 300 440 309.7 22 365 4 342 323.9 62 12 22 395 14.26
insert! 350 490 341.4 22 415 4 385 355.6 62 12 22 445 18.56
insert! 350 490 353.8 22 415 4 385 368 62 12 22 445 16.76
insert! 400 540 392.2 22 465 4 438 406.4 65 16 22 495 21.25
insert! 400 540 404.8 22 465 4 438 419 65 16 22 495 19.1
insert! 500 645 491.8 24 570 4 538 506 68 20 22 600 23.57
insert! 600 755 595.8 24 670 5 640 610 70 20 26 705 34.5
insert! 700 660 696.8 24 775 5 740 711 70 24 26 810 40
insert! 800 975 798.8 24 880 5 842 813 70 24 30 920 48.18
insert! 900 1075 899.8 26 980 5 942 914 70 24 30 1020 58.1
insert! 1000 1175 1001.8 26 1080 5 1045 1016 70 25 30 1120 63.41
insert! 1200 1375 1206 26 1280 5 1245 1220 70 32 30 1320 72.82
insert! 1400 1575 1406 26 1480 5 1445 1420 70 36 30 1520 84.5
insert! 1600 1790 1604 26 1680 5 1645 1620 80 40 30 1730 111.57
insert! 1800 1990 1802 26 1890 5 1845 1820 80 44 30 1930 128.41
insert! 2000 2190 2000 26 2090 5 2045 2020 80 48 30 2130 145
insert! 2200 2405 2200 28 2295 6 2248 2220 90 52 33 2340 184.1
insert! 2400 2605 2400 28 2495 6 2448 2420 90 56 32 2540 200.47
insert! 2600 2805 2600 28 2695 6 2648 2620 90 60 33 2740 216
insert! 2800 3030 2800 30 2910 6 2848 2820 90 64 36 2960 268.05
insert! 3000 3230 3000 30 3110 6 3050 3020 90 66 36 3160 285
insert! 3200 3430 3200 30 3310 6 3250 3220 90 72 36 3350 306.75
insert! 3400 3630 3400 32 3510 6 3450 3420 95 76 36 3560 346.71
insert! 3600 3340 3600 32 3720 6 3652 3620 100 80 36 3770 305.71
insert! 3800 4045 3800 34 3920 6 3852 3820 100 80 0 3970 0
insert! 4000 4245 4000 34 4120 6 4052 4020 100 84 0 4170 0
custom!
Length
Color
Offset
ISO and DIN dimensions.
Edit
undo! - redo!
Color
View
Make Component
Rotate Object(s)
Move or Copy Object(s)
The Knife
YouTube demo of the Knife!
Change Insertion Point
Insert Line
red green blue - End position
Insert Horizontal Plane
Insert Vertical Plane
Insert Box
Insert external Component
insert! name url
