Dimensions, sizes and specifications of DIN 2631 Welding Neck Flanges PN6/6BAR
NB! If there is problem with inserting flanges - try to reinstall the extension by using alternative 3 as described in the right column.
Nominal Size | Outside Diameter of Flange | Diameter Bore | Thickness of Flange | Diameter of Raised Face | Height of Raised Face | Diameter of Hub at Base | Diameter of Hub at Point of Welding | Length through Hub | No. of Holes | Diameter of Holes | Diameter of Bolts | Diameter of Bolt Circle | Weight | |
mm | mm | mm | mm | mm | mm | mm | mm | mm | mm | mm | mm | kg | ||
insert! | 10 | 75 | 10.4 | 12 | 35 | 2 | 22 | 14 | 28 | 4 | 11 | 50 | 0.34 | |
insert! | 10 | 75 | 13.6 | 12 | 35 | 2 | 26 | 17.2 | 28 | 4 | 11 | 50 | 0.34 | |
insert! | 15 | 80 | 16 | 12 | 40 | 2 | 28 | 20 | 30 | 4 | 11 | 55 | 0.39 | |
insert! | 15 | 80 | 17.3 | 12 | 40 | 2 | 30 | 21.3 | 30 | 4 | 11 | 55 | 0.4 | |
insert! | 20 | 90 | 20.4 | 14 | 50 | 2 | 35 | 25 | 32 | 4 | 11 | 65 | 0.6 | |
insert! | 20 | 90 | 22.3 | 14 | 50 | 2 | 38 | 26.9 | 32 | 4 | 11 | 65 | 0.6 | |
insert! | 25 | 100 | 24.8 | 14 | 60 | 2 | 40 | 30 | 35 | 4 | 11 | 75 | 0.76 | |
insert! | 25 | 100 | 28.5 | 14 | 60 | 2 | 42 | 33.7 | 35 | 4 | 11 | 75 | 0.75 | |
insert! | 32 | 120 | 32.8 | 14 | 70 | 2 | 50 | 38 | 35 | 4 | 14 | 90 | 1.07 | |
insert! | 32 | 120 | 37.2 | 14 | 70 | 2 | 55 | 42.4 | 35 | 4 | 14 | 90 | 1.06 | |
insert! | 40 | 130 | 39.3 | 14 | 80 | 3 | 58 | 44.5 | 38 | 4 | 14 | 100 | 1.21 | |
insert! | 40 | 130 | 41.1 | 14 | 80 | 3 | 62 | 46.3 | 38 | 4 | 14 | 100 | 1.2 | |
insert! | 50 | 140 | 51.2 | 14 | 90 | 3 | 70 | 57 | 38 | 4 | 14 | 110 | 1.37 | |
insert! | 50 | 140 | 54.5 | 14 | 90 | 3 | 74 | 60.3 | 38 | 4 | 14 | 110 | 1.36 | |
insert! | 65 | 160 | 70.3 | 14 | 110 | 3 | 88 | 76.1 | 38 | 4 | 14 | 130 | 1.69 | |
insert! | 80 | 190 | 82.5 | 16 | 128 | 3 | 102 | 88.9 | 42 | 4 | 18 | 150 | 2.72 | |
insert! | 100 | 210 | 100.8 | 16 | 148 | 3 | 122 | 108 | 45 | 4 | 18 | 170 | 3.29 | |
insert! | 100 | 210 | 107.1 | 16 | 148 | 3 | 130 | 114.3 | 45 | 4 | 18 | 170 | 3.22 | |
insert! | 125 | 240 | 125 | 18 | 178 | 3 | 148 | 133 | 48 | 8 | 18 | 200 | 4.58 | |
insert! | 125 | 240 | 131.7 | 18 | 178 | 3 | 155 | 139.7 | 48 | 8 | 18 | 200 | 4.42 | |
insert! | 150 | 265 | 150 | 18 | 202 | 3 | 172 | 159 | 48 | 8 | 18 | 225 | 5.26 | |
insert! | 150 | 265 | 149.3 | 18 | 202 | 3 | 184 | 158.3 | 48 | 8 | 18 | 225 | 5.04 | |
insert! | 200 | 320 | 207.3 | 20 | 258 | 3 | 236 | 219.1 | 55 | 8 | 18 | 280 | 7.95 | |
insert! | 250 | 375 | 254.4 | 22 | 312 | 3 | 282 | 267 | 60 | 12 | 18 | 335 | 11.16 | |
insert! | 250 | 375 | 260.4 | 22 | 312 | 3 | 290 | 273 | 60 | 12 | 18 | 335 | 10.87 | |
insert! | 300 | 440 | 309.7 | 22 | 365 | 4 | 342 | 323.9 | 62 | 12 | 22 | 395 | 14.26 | |
insert! | 350 | 490 | 341.4 | 22 | 415 | 4 | 385 | 355.6 | 62 | 12 | 22 | 445 | 18.54 | |
insert! | 350 | 490 | 353.8 | 22 | 415 | 4 | 385 | 368 | 62 | 12 | 22 | 445 | 16.78 | |
insert! | 400 | 540 | 392.4 | 22 | 465 | 4 | 438 | 406.6 | 65 | 16 | 22 | 495 | 21.25 | |
insert! | 400 | 540 | 404.8 | 22 | 465 | 4 | 438 | 419 | 65 | 16 | 22 | 495 | 19.1 | |
insert! | 500 | 645 | 493.8 | 24 | 570 | 4 | 538 | 508 | 68 | 20 | 22 | 600 | 28.67 | |
insert! | 600 | 755 | 595.8 | 24 | 670 | 5 | 640 | 610 | 70 | 20 | 26 | 705 | 34.8 | |
insert! | 700 | 860 | 696.8 | 24 | 775 | 5 | 740 | 711 | 70 | 24 | 26 | 810 | 40.94 | |
insert! | 800 | 975 | 798.8 | 24 | 880 | 5 | 842 | 813 | 70 | 24 | 30 | 920 | 49.19 | |
insert! | 900 | 1075 | 899.8 | 26 | 980 | 5 | 942 | 914 | 70 | 24 | 30 | 1020 | 58.1 | |
insert! | 1000 | 1175 | 1001.8 | 26 | 1080 | 5 | 1045 | 1016 | 70 | 28 | 30 | 1120 | 63.48 | |
insert! | 1200 | 1405 | 1204 | 28 | 1295 | 5 | 1248 | 1220 | 90 | 32 | 33 | 1340 | 100.17 | |
insert! | 1400 | 1630 | 1404 | 32 | 1510 | 5 | 1452 | 1420 | 90 | 36 | 36 | 1560 | 142.78 | |
insert! | 1600 | 1830 | 1602 | 34 | 1710 | 5 | 1655 | 1620 | 90 | 40 | 36 | 1760 | 174.36 | |
insert! | 1800 | 2045 | 1800 | 36 | 1920 | 5 | 1855 | 1820 | 100 | 44 | 39 | 1970 | 226.98 | |
insert! | 2000 | 2265 | 1998 | 38 | 2125 | 5 | 2058 | 2020 | 110 | 48 | 42 | 2180 | 292.12 | |
insert! | 2200 | 2475 | 2196 | 42 | 2335 | 6 | 2260 | 2220 | 115 | 52 | 42 | 2390 | 366.33 | |
insert! | 2400 | 2685 | 2394 | 44 | 2545 | 6 | 2462 | 2420 | 125 | 56 | 42 | 2600 | 448.52 | |
insert! | 2600 | 2905 | 2592 | 46 | 2750 | 6 | 2665 | 2620 | 130 | 60 | 48 | 2810 | 540.16 | |
insert! | 2800 | 3115 | 2790 | 48 | 2960 | 6 | 2865 | 2820 | 135 | 64 | 48 | 3020 | 630.03 | |
insert! | 3000 | 3315 | 2988 | 50 | 3160 | 6 | 3068 | 3020 | 140 | 68 | 48 | 3220 | 716.33 | |
insert! | 3200 | 3525 | 3188 | 54 | 3370 | 6 | 3272 | 3220 | 150 | 72 | 48 | 3430 | 854.42 | |
insert! | 3400 | 3735 | 3384 | 46 | 3580 | 6 | 3475 | 3420 | 160 | 76 | 48 | 3640 | 887.81 | |
insert! | 3600 | 3970 | 3584 | 60 | 3790 | 6 | 3678 | 3620 | 165 | 80 | 56 | 3860 | 1202.43 | |
custom! |
ISO Series 1 and DIN Series 2
undo! redo!
change color!
make!
startpoint
endpoint insert!
It's FREE and FUN!
and more.
3 18
