Welding Neck ASME B16.5 FLanges 1500 lbs
| Nominal Size | Outside Diameter of Flange | Diameter Bore | Thickness of Flange | Diameter of Raised Face | Height of Raised Face | Diameter of Hub at Base | Diameter of Hub at Point of Welding | Length through Hub | No. of Holes | Diameter of Holes | Diameter of Bolts | Diameter of Bolt Circle | Weight | |
| in | in | in | in | in | in | in | in | in | in | in | in | lbs | ||
| insert! | 1/2 | 4.75 | 0.55 | 0.88 | 1.38 | 0.25 | 1.5 | 0.84 | 2.38 | 4 | 0.88 | 3/4 | 3.25 | 5 |
| insert! | 3/4 | 5.12 | 0.74 | 1 | 1.69 | 0.25 | 1.75 | 1.05 | 2.75 | 4 | 0.88 | 3/4 | 3.5 | 6 |
| insert! | 1 | 5.88 | 0.96 | 1.12 | 2 | 0.25 | 2.06 | 1.32 | 2.88 | 4 | 1 | 7/8 | 4 | 9 |
| insert! | 1 1/4 | 6.25 | 1.28 | 1.12 | 2.5 | 0.25 | 2.5 | 1.66 | 2.88 | 4 | 1 | 7/8 | 4.38 | 10 |
| insert! | 1 1/2 | 7 | 1.5 | 1.25 | 2.88 | 0.25 | 2.75 | 1.9 | 3.25 | 4 | 1.12 | 1 | 4.88 | 13 |
| insert! | 2 | 8.5 | 1.94 | 1.5 | 3.62 | 0.25 | 4.12 | 2.38 | 4 | 8 | 1 | 7/8 | 6.5 | 25 |
| insert! | 2 1/2 | 9.62 | 2.31 | 1.62 | 4.12 | 0.25 | 4.88 | 2.88 | 4.12 | 8 | 1.12 | 1 | 7.5 | 36 |
| insert! | 3 | 10.5 | 2.9 | 1.88 | 5 | 0.25 | 5.25 | 3.5 | 4.62 | 8 | 1.25 | 1 1/8 | 8 | 48 |
| insert! | 4 | 12.25 | 3.83 | 2.12 | 6.19 | 0.25 | 6.38 | 4.5 | 4.88 | 8 | 1.38 | 1 1/4 | 9.5 | 73 |
| insert! | 5 | 14.75 | 4.81 | 2.88 | 7.31 | 0.25 | 7.75 | 5.56 | 6.12 | 8 | 1.62 | 1 1/2 | 11.5 | 130 |
| insert! | 6 | 15.5 | 5.75 | 3.25 | 8.5 | 0.25 | 9 | 6.63 | 6.75 | 12 | 1.5 | 1 3/8 | 12.5 | 165 |
| insert! | 8 | 19 | 7.63 | 3.62 | 10.62 | 0.25 | 11.5 | 8.63 | 8.38 | 12 | 1.75 | 1 5/8 | 15.5 | 275 |
| insert! | 10 | 23 | 9.75 | 4.25 | 12.75 | 0.25 | 14.5 | 10.75 | 10 | 12 | 2 | 1 7/8 | 19 | 455 |
| insert! | 12 | 26.5 | 11.75 | 4.88 | 15 | 0.25 | 17.75 | 12.75 | 11.12 | 16 | 2.12 | 2 | 22.5 | 690 |
| insert! | 14 | 29.5 | 13 | 5.25 | 16.25 | 0.25 | 19.5 | 14 | 11.75 | 16 | 2.38 | 2 1/4 | 25 | 940 |
| insert! | 16 | 32.5 | 15 | 5.75 | 18.5 | 0.25 | 21.75 | 16 | 12.25 | 16 | 2.62 | 2 1/2 | 27.75 | 1250 |
| insert! | 18 | 36 | 17 | 6.38 | 21 | 0.25 | 23.5 | 18 | 12.88 | 16 | 2.88 | 2 3/4 | 30.5 | 1625 |
| insert! | 20 | 38.75 | 19 | 7 | 23 | 0.25 | 25.25 | 20 | 14 | 16 | 3.12 | 3 | 32.75 | 2050 |
| insert! | 24 | 46 | 23 | 8 | 27.25 | 0.25 | 30 | 24 | 16 | 16 | 3.62 | 3 1/2 | 39 | 3325 |
| custom! | ||||||||||||||
Edit:
undo -
redo
Color:
change color!
View:
iso -
top -
front -
right -
left -
back -
bottom
Make Component:
Rotate Object(s):
degrees around
red,
green or
blue
move/copy!
no. copies
red
green
blue
with multiple copies.
move!
New! Change Insertion Point
red
green
blue
- Start position
red
green
blue
- End position
insert!
insert!
red (size)
green (size)
blue (vertical position)
insert!
red (horizontal position)
green (size)
blue (vertical size)
insert!
red (size)
green (horizontal position)
Insert Box: - add a box
insert!
red (width)
green (depth)
blue (height)
insert!
name
url
10 3 19
It's FREE and
it's FUN!
Download
engineeringtoolbox.rb
Exit and reload SketchUp!
or
(Mac)
(Mac users look here!)
add components to the
groups!
on Mac computers.
