Home  > Piping  > Flanges  >
DIN 2628 Welding Neck Flanges PN250/250BAR
Dimensions, sizes and specifications of DIN 2628 Welding Neck Flanges PN250/250BAR
Nominal Size Outside Diameter of Flange Diameter Bore Thickness of Flange Diameter of Raised Face Height of Raised Face Diameter of Hub at Base Diameter of Hub at Point of Welding Length through Hub No. of Holes Diameter of Holes Diameter of Bolts Diameter of Bolt Circle Weight
mm mm mm mm mm mm mm mm mm mm mm mm kg
insert! 10 125 8.8 24 40 2 44 14 58 4 18 85 2.1
insert! 10 125 12 24 40 2 44 17.2 58 4 18 85 2.09
insert! 15 130 14.8 26 45 2 48 20 60 4 18 90 2.48
insert! 15 130 16.1 26 45 2 48 21.3 60 4 18 90 2.47
insert! 25 150 22.8 28 68 2 60 30 65 4 22 105 3.56
insert! 25 150 26.5 28 68 2 60 33.7 65 4 22 105 3.53
insert! 40 185 34.5 34 88 3 84 44.5 80 4 26 135 6.65
insert! 40 185 38.3 34 88 3 84 48.3 80 4 26 135 6.58
insert! 50 200 44.4 38 102 3 95 57 85 8 26 150 8.17
insert! 50 200 47.7 38 102 3 95 60.3 85 8 26 150 8.09
insert! 65 230 60.1 42 122 3 124 76.1 95 8 26 180 12.59
insert! 80 255 79.6 46 138 3 136 101.6 102 8 30 200 16.32
insert! 100 300 98.6 54 162 3 164 127 120 8 33 235 27.07
insert! 125 340 120.4 60 188 3 200 152.4 140 12 33 275 38.79
insert! 150 390 142.8 68 218 3 240 177.8 160 12 36 320 59.05
insert! 200 485 194.5 82 285 3 305 244.5 190 12 42 400 109.45
insert! 250 585 234.5 100 345 3 385 298.5 215 16 48 490 189.94
insert! 250 355 143.3 50 218 3 210 168.3 128 12 33 290 34.02
insert! 175 390 165.3 54 260 3 245 193.7 138 12 36 320 44.9
insert! 200 490 187.1 60 285 3 278 219.1 140 12 36 360 60.03
insert! 250 515 227 68 345 3 340 267 155 12 42 430 98.05
insert! 250 515 233 68 345 3 340 273 155 12 42 430 96.52
custom!
Length
Color
Offset
ISO and DIN dimensions.
Edit
undo! - redo!
Color
View
Make Component
Rotate Object(s)
Move or Copy Object(s)
The Knife
YouTube demo of the Knife!
Change Insertion Point
Insert Line
red green blue - End position
Insert Horizontal Plane
Insert Vertical Plane
Insert Box
Insert external Component
insert! name url
