Dimensions, sizes and specifications of DIN 2629 Welding Neck Flanges PN320/320BAR
NB! If there is problem with inserting flanges - try to reinstall the extension by using alternative 3 as described in the right column.
Nominal Size | Outside Diameter of Flange | Diameter Bore | Thickness of Flange | Diameter of Raised Face | Height of Raised Face | Diameter of Hub at Base | Diameter of Hub at Point of Welding | Length through Hub | No. of Holes | Diameter of Holes | Diameter of Bolts | Diameter of Bolt Circle | Weight | |
mm | mm | mm | mm | mm | mm | mm | mm | mm | mm | mm | mm | kg | ||
insert! | 10 | 125 | 8.8 | 24 | 40 | 2 | 44 | 14 | 58 | 4 | 18 | 85 | 2.1 | |
insert! | 10 | 125 | 12 | 24 | 40 | 2 | 44 | 17.2 | 58 | 4 | 18 | 85 | 2.09 | |
insert! | 15 | 130 | 13.6 | 26 | 45 | 2 | 48 | 20 | 60 | 4 | 18 | 90 | 2.49 | |
insert! | 15 | 130 | 14.9 | 26 | 45 | 2 | 48 | 21.3 | 60 | 4 | 18 | 90 | 2.49 | |
insert! | 25 | 160 | 20 | 34 | 68 | 2 | 68 | 30 | 78 | 4 | 22 | 115 | 5.14 | |
insert! | 25 | 160 | 23.7 | 34 | 68 | 2 | 68 | 33.7 | 78 | 4 | 22 | 115 | 5.11 | |
insert! | 40 | 195 | 31.9 | 38 | 88 | 3 | 92 | 44.5 | 88 | 4 | 26 | 145 | 8.53 | |
insert! | 40 | 195 | 32.7 | 38 | 88 | 3 | 92 | 45.3 | 88 | 4 | 26 | 145 | 8.47 | |
insert! | 50 | 210 | 47.5 | 42 | 102 | 3 | 106 | 63.5 | 100 | 8 | 26 | 160 | 10.52 | |
insert! | 65 | 255 | 66.9 | 51 | 122 | 3 | 138 | 88.9 | 120 | 8 | 30 | 200 | 19.26 | |
insert! | 80 | 275 | 76.6 | 55 | 138 | 3 | 156 | 101.6 | 130 | 8 | 30 | 220 | 24.81 | |
insert! | 100 | 335 | 101 | 65 | 162 | 3 | 186 | 133 | 145 | 8 | 36 | 265 | 42.18 | |
insert! | 125 | 380 | 119 | 75 | 188 | 3 | 230 | 159 | 175 | 12 | 36 | 310 | 64.55 | |
insert! | 125 | 380 | 128.3 | 75 | 188 | 3 | 230 | 168.3 | 175 | 12 | 36 | 310 | 63.3 | |
insert! | 150 | 425 | 143.7 | 84 | 218 | 3 | 265 | 193.7 | 195 | 12 | 36 | 350 | 91.04 | |
insert! | 175 | 485 | 163.1 | 95 | 260 | 3 | 308 | 219.1 | 215 | 12 | 42 | 400 | 135.46 | |
insert! | 200 | 525 | 184.5 | 103 | 285 | 3 | 345 | 244.5 | 235 | 16 | 42 | 440 | 170.94 | |
insert! | 250 | 640 | 243.9 | 125 | 345 | 3 | 428 | 323.9 | 300 | 16 | 52 | 540 | 311.99 | |
custom! |
ISO and DIN dimensions.
Tip! - use the "Rotate Object" bellow to turn the object after it is inserted.
undo! redo!
change color!
make!
startpoint
endpoint insert!
It's FREE and FUN!
and more.
3 18
