Slip-on ASME B16.5 FLanges 600 lbs
NB! If there is problem with inserting flanges - try to reinstall the extension by using alternative 3 as described in the right column.
Nominal Size in |
Outside Diameter of Flange in |
Diameter Bore in |
Thickness of Flange in |
Diameter of Raised Face in |
Height of Raised Face in |
Diameter of Hub at Base in |
Length through Hub in |
No. of Holes |
Diameter of Holes in |
Diameter of Bolts in |
Diameter of Bolt Circle in |
Weight lbs |
| insert! | 1/2 | 3.75 | 0.88 | 0.56 | 1.38 | 0.25 | 1.5 | 0.88 | 4 | 0.62 | 1/2 | 2.62 | 2 |
| insert! | 3/4 | 4.62 | 1.09 | 0.62 | 1.69 | 0.25 | 1.88 | 1 | 4 | 0.75 | 5/8 | 3.25 | 3 |
| insert! | 1 | 4.88 | 1.36 | 0.69 | 2 | 0.25 | 2.12 | 1.06 | 4 | 0.75 | 5/8 | 3.5 | 3.5 |
| insert! | 1 1/4 | 5.25 | 1.7 | 0.81 | 2.5 | 0.25 | 2.5 | 1.12 | 4 | 0.75 | 5/8 | 3.88 | 4.5 |
| insert! | 1 1/2 | 6.12 | 1.95 | 0.88 | 2.88 | 0.25 | 2.75 | 1.25 | 4 | 0.88 | 3/4 | 4.5 | 6.5 |
| insert! | 2 | 6.5 | 2.44 | 1 | 3.62 | 0.25 | 3.31 | 1.44 | 8 | 0.75 | 5/8 | 5 | 8 |
| insert! | 2 1/2 | 7.5 | 2.94 | 1.12 | 4.12 | 0.25 | 3.94 | 1.62 | 8 | 0.88 | 3/4 | 5.88 | 12 |
| insert! | 3 | 8.25 | 3.57 | 1.25 | 5 | 0.25 | 4.62 | 1.81 | 8 | 0.88 | 3/4 | 6.62 | 15 |
| insert! | 3 1/2 | 9 | 4.07 | 1.38 | 5.5 | 0.25 | 5.25 | 1.94 | 8 | 1 | 7/8 | 7.25 | 21 |
| insert! | 4 | 10.75 | 4.57 | 1.5 | 6.19 | 0.25 | 6 | 2.12 | 8 | 1 | 7/8 | 8.5 | 33 |
| insert! | 5 | 13 | 5.66 | 1.75 | 7.31 | 0.25 | 7.44 | 2.38 | 8 | 1.12 | 1 | 10.5 | 63 |
| insert! | 6 | 14 | 6.72 | 1.88 | 8.5 | 0.25 | 8.75 | 2.62 | 12 | 1.12 | 1 | 11.5 | 80 |
| insert! | 8 | 16.5 | 8.72 | 2.19 | 10.62 | 0.25 | 10.75 | 3 | 12 | 1.25 | 1 1/8 | 13.75 | 97 |
| insert! | 10 | 20 | 10.88 | 2.5 | 12.75 | 0.25 | 13.5 | 3.38 | 16 | 1.38 | 1 1/4 | 17 | 177 |
| insert! | 12 | 22 | 12.88 | 2.62 | 15 | 0.25 | 15.75 | 3.62 | 20 | 1.38 | 1 1/4 | 19.25 | 215 |
| insert! | 14 | 23.75 | 14.14 | 2.75 | 16.25 | 0.25 | 17 | 3.69 | 20 | 1.5 | 1 3/8 | 20.75 | 259 |
| insert! | 16 | 27 | 16.16 | 3 | 18.5 | 0.25 | 19.5 | 4.19 | 20 | 1.62 | 1 1/2 | 23.75 | 366 |
| insert! | 18 | 29.25 | 18.18 | 3.25 | 21 | 0.25 | 21.5 | 4.62 | 20 | 1.75 | 1 5/8 | 25.75 | 476 |
| insert! | 20 | 32 | 20.2 | 3.5 | 23 | 0.25 | 24 | 5 | 24 | 1.75 | 1 5/8 | 28.5 | 612 |
| insert! | 24 | 37 | 24.25 | 4 | 27.25 | 0.25 | 28.25 | 5.5 | 24 | 2 | 1 7/8 | 33 | 876 |
| custom! |
undo! redo!
change color!
make!
startpoint
endpoint insert!
It's FREE and FUN!
If you experience problems with the functionality - first try to reload the cached page with the link in the top left corner - then try installation with alternative 2 or 3.
Note! The Engineering Toolbox extension in Sketchup Extension Warehouse only works for Sketchup editions up to 2023. For Sketchup edition 2024 and higher the extension can be installed by using installation alternative 2 or 3 below.
and more.
10 16
