Sign in!
Home > Piping > Flanges >
ASME B16.5 - Blind Flanges - 600 lbs
Blind flanges ASME B16.5
blind flange 600 lbs
Nominal SizeOutside Diameter of FlangeThickness of FlangeDiameter of Raised FaceHeight of Raised FaceNo. of HolesDiameter of HolesDiameter of BoltsDiameter of Bolt CircleWeight
ininininininininlbs
insert!1/23.750.561.380.2540.621/22.622
insert!3/44.620.621.690.2540.755/83.253
insert!14.880.6920.2540.755/83.54
insert!1 1/45.250.812.50.2540.755/83.886
insert!1 1/26.120.882.880.2540.883/44.58
insert!26.513.620.2580.755/8510
insert!2 1/27.51.124.120.2580.883/45.8815
insert!38.251.2550.2580.883/46.6220
insert!3 1/291.385.50.25817/87.2529
insert!410.751.56.190.25817/88.541
insert!5131.757.310.2581.12110.568
insert!6141.888.50.25121.12111.586
insert!816.52.1910.620.25121.251 1/813.75139
insert!10202.512.750.25161.381 1/417231
insert!12222.62150.25201.381 1/419.25295
insert!1423.752.7516.250.25201.51 3/820.75378
insert!1627318.50.25201.621 1/223.75527
insert!1829.253.25210.25201.751 5/825.75665
insert!20323.5230.25241.751 5/828.5855
insert!2437427.250.252421 7/8331175
custom!
ininininininininlbs
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
10 3 21
