Sign in!
Home > Piping > Flanges >
ASME B16.5 Slip-on Flanges - 300 lbs
Slip-on ASME B16.5 FLanges 300 lbs
slip-on flange 300 lbs
Nominal SizeOutside Diameter of FlangeDiameter BoreThickness of FlangeDiameter of Raised FaceHeight of Raised FaceDiameter of Hub at BaseLength through HubNo. of HolesDiameter of HolesDiameter of BoltsDiameter of Bolt CircleWeight
inininininininininininlbs
insert!1/23.750.880.561.380.06251.50.8840.621/22.621.5
insert!3/44.621.090.621.690.06251.88140.755/83.252.5
insert!14.881.360.6920.06252.121.0640.755/83.53
insert!1 1/45.251.70.752.50.06252.51.0640.755/83.884.5
insert!1 1/26.121.950.812.880.06252.751.1940.883/44.56.5
insert!26.52.440.883.620.06253.311.3180.755/857
insert!2 1/27.52.9414.120.06253.941.580.883/45.8810
insert!38.253.571.1250.06254.621.6980.883/46.6213
insert!3 1/294.071.195.50.06255.251.7580.883/47.2516
insert!4104.571.256.190.06255.751.8880.883/47.8823.5
insert!5115.661.387.310.06257280.883/49.2529
insert!612.56.721.448.50.06258.122.06120.883/410.6236
insert!8158.721.6210.620.062510.252.441217/81356
insert!1017.510.881.8812.750.062512.622.62161.12115.2577
insert!1220.512.882150.062514.752.88161.251 1/817.75113
insert!142314.142.1216.250.062516.753201.251 1/820.25159
insert!1625.516.162.2518.50.0625193.25201.381 1/422.5210
insert!182818.182.38210.0625213.5241.381 1/424.75253
insert!2030.520.22.5230.062523.123.75241.381 1/427307
insert!243624.252.7527.250.062527.624.19241.621 1/232490
custom!
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
9 11 22
