Dimension and weight of DIN 2502 Plate Flanges PN16
NB! If there is problem with inserting flanges - try to reinstall the extension by using alternative 3 as described in the right column.
Nominal Size | Outside Diameter of Flange | Diameter Bore | Thickness of Flange | No. of Holes | Diameter of Holes | Diameter of Bolts | Diameter of Bolt Circle | Weight | |
mm | mm | mm | mm | mm | mm | mm | kg | ||
insert! | 10 | 90 | 14.5 | 14 | 4 | 14 | 60 | 0.61 | |
insert! | 10 | 90 | 17.7 | 14 | 4 | 14 | 60 | 0.6 | |
insert! | 15 | 95 | 21 | 14 | 4 | 14 | 65 | 0.67 | |
insert! | 15 | 95 | 22 | 14 | 4 | 14 | 65 | 0.67 | |
insert! | 20 | 105 | 26 | 16 | 4 | 14 | 75 | 0.94 | |
insert! | 20 | 105 | 27.6 | 16 | 4 | 14 | 75 | 0.94 | |
insert! | 25 | 115 | 31 | 16 | 4 | 14 | 85 | 1.13 | |
insert! | 25 | 115 | 34.4 | 16 | 4 | 14 | 85 | 1.11 | |
insert! | 32 | 140 | 39 | 16 | 4 | 18 | 100 | 1.66 | |
insert! | 32 | 140 | 43.1 | 16 | 4 | 18 | 100 | 1.62 | |
insert! | 40 | 150 | 45.5 | 16 | 4 | 18 | 110 | 1.89 | |
insert! | 40 | 150 | 49 | 16 | 4 | 18 | 110 | 1.85 | |
insert! | 50 | 165 | 58.1 | 18 | 4 | 18 | 125 | 2.5 | |
insert! | 50 | 165 | 61.1 | 18 | 4 | 18 | 125 | 2.46 | |
insert! | 65 | 185 | 77.1 | 18 | 4 | 18 | 145 | 2.99 | |
insert! | 80 | 200 | 90.3 | 20 | 8 | 18 | 160 | 3.61 | |
insert! | 100 | 220 | 109.6 | 20 | 8 | 18 | 180 | 4.17 | |
insert! | 100 | 220 | 115.9 | 20 | 8 | 18 | 180 | 3.99 | |
insert! | 125 | 250 | 134.8 | 22 | 8 | 18 | 210 | 5.66 | |
insert! | 125 | 250 | 141.6 | 22 | 8 | 18 | 210 | 5.41 | |
insert! | 150 | 285 | 161.1 | 22 | 8 | 22 | 240 | 6.97 | |
insert! | 150 | 285 | 170.5 | 22 | 8 | 22 | 240 | 6.55 | |
insert! | 175 | 315 | 196.1 | 24 | 8 | 22 | 270 | 8.42 | |
insert! | 200 | 340 | 221.8 | 24 | 12 | 22 | 295 | 8.97 | |
insert! | 250 | 405 | 270.2 | 26 | 12 | 26 | 355 | 13.29 | |
insert! | 250 | 405 | 276.2 | 26 | 12 | 26 | 355 | 12.76 | |
insert! | 300 | 460 | 327.6 | 28 | 12 | 26 | 410 | 16.6 | |
insert! | 350 | 520 | 359.7 | 30 | 16 | 26 | 470 | 24.08 | |
insert! | 350 | 520 | 372.2 | 30 | 16 | 26 | 470 | 22.39 | |
insert! | 400 | 580 | 411 | 32 | 16 | 30 | 525 | 30.2 | |
insert! | 400 | 580 | 423.7 | 32 | 16 | 30 | 525 | 28.11 | |
insert! | 450 | 640 | 462.3 | 38 | 20 | 30 | 585 | 41.67 | |
insert! | 500 | 715 | 513.6 | 38 | 20 | 33 | 650 | 52.87 | |
insert! | 600 | 840 | 616.5 | 42 | 20 | 36 | 770 | 77.58 | |
insert! | 700 | 910 | 716 | 44 | 24 | 36 | 840 | 77.13 | |
insert! | 800 | 1025 | 818 | 50 | 24 | 39 | 950 | 106.35 | |
insert! | 900 | 1125 | 920 | 54 | 28 | 39 | 1050 | 125.39 | |
insert! | 1000 | 1255 | 1022 | 60 | 28 | 42 | 1170 | 177.99 | |
custom! |
ISO Series 1 and DIN Series 2
undo! redo!
change color!
make!
startpoint
endpoint insert!
It's FREE and FUN!
and more.
3 18
