Home  > Piping  > Flanges  >
DIN 2632 Welding Neck Flanges PN10/10BAR
Dimensions, sizes and specifications of DIN 2632 Welding Neck Flanges PN10/10BAR
Nominal Size Outside Diameter of Flange Diameter Bore Thickness of Flange Diameter of Raised Face Height of Raised Face Diameter of Hub at Base Diameter of Hub at Point of Welding Length through Hub No. of Holes Diameter of Holes Diameter of Bolts Diameter of Bolt Circle Weight
mm mm mm mm mm mm mm mm mm mm mm mm kg
insert! 10 90 10.4 14 40 2 25 14 35 4 14 60 0.58
insert! 10 90 13.6 14 40 2 28 17.2 35 4 14 60 0.58
insert! 15 95 16 14 45 2 30 20 35 4 14 65 0.65
insert! 15 95 17.3 14 45 2 32 21.3 35 4 14 65 0.65
insert! 20 105 20.4 16 58 2 38 25 38 4 14 75 0.95
insert! 20 105 22.3 16 58 2 40 26.9 38 4 14 75 0.95
insert! 25 115 24.8 16 68 2 42 30 38 4 14 85 1.15
insert! 25 115 28.5 16 68 2 45 33.7 38 4 14 85 1.14
insert! 32 140 32.8 16 78 2 52 38 40 4 18 100 1.67
insert! 32 140 37.2 16 78 2 55 42.4 40 4 18 100 1.65
insert! 40 150 39.3 16 88 3 60 44.5 42 4 18 110 1.85
insert! 40 150 43.1 16 88 3 64 48.3 42 4 18 110 1.83
insert! 50 165 51.2 18 102 3 72 57 45 4 18 125 2.51
insert! 50 165 54.5 18 102 3 75 60.3 45 4 18 125 2.48
insert! 65 165 70.3 18 122 3 90 76.1 45 4 18 145 3.03
insert! 80 200 82.5 20 138 3 105 88.9 50 8 18 160 3.82
insert! 100 220 100.8 20 158 3 125 108 52 8 18 180 4.54
insert! 100 220 107.1 20 158 3 131 114.3 52 8 18 180 4.41
insert! 125 250 125 22 188 3 150 133 55 8 18 210 6.28
insert! 125 250 131.7 22 188 3 156 139.7 55 8 18 210 6.07
insert! 150 285 150 22 212 3 175 159 55 8 22 240 7.75
insert! 150 285 159.3 22 212 3 184 168.3 55 8 22 240 7.4
insert! 200 340 207.3 24 268 3 235 219.1 62 8 22 295 11.1
insert! 250 395 254.4 26 320 3 285 267 68 12 22 350 15.31
insert! 250 395 260.4 26 320 3 292 273 68 12 22 350 14.92
insert! 300 445 309.7 26 370 4 344 323.9 68 12 22 400 17.47
insert! 350 505 341.4 26 430 4 385 355.6 66 16 22 460 23.7
insert! 350 505 353.8 26 430 4 385 368 68 16 22 460 21.71
insert! 400 565 392.2 26 482 4 440 406.4 72 16 26 515 28.72
insert! 400 565 404.8 26 482 4 440 419 72 16 26 515 26.27
insert! 450 615 443 26 532 4 478 457.2 72 20 26 565 30.4
insert! 500 670 493.8 28 585 4 542 508 75 20 26 620 38.27
insert! 600 780 595.8 28 685 5 642 610 80 20 30 725 46.56
insert! 700 895 695 30 800 5 745 711 80 24 30 840 62.3
insert! 800 1015 797 32 905 5 850 813 90 24 33 950 83.81
insert! 900 1115 894 34 1005 5 950 914 95 28 33 1050 102.45
insert! 1000 1230 996 34 1110 5 1052 1016 95 28 36 1160 118.53
insert! 1200 1455 1198 36 1330 5 1255 1220 115 32 39 1380 178.18
insert! 1400 1675 1396 42 1535 5 1460 1420 120 36 42 1590 244.75
insert! 1600 1915 1592 46 1760 5 1665 1620 130 40 48 1820 353.74
insert! 1800 2115 1790 50 1960 5 1868 1820 140 44 48 2020 436.33
insert! 2000 2325 1988 54 2170 5 2072 2020 150 46 48 2230 548.04
insert! 2200 2550 2184 58 2370 5 2275 2220 160 52 56 2440 685.1
insert! 2400 2760 2380 62 2570 5 2478 2420 170 56 56 2650 640.04
insert! 2600 2860 2576 66 2780 6 2690 2620 180 60 56 2850 990.16
insert! 2800 3180 2776 70 3000 6 2882 2820 190 64 56 3070 1187.16
insert! 3000 3405 2972 75 3210 6 3085 3020 200 65 62 3290 1437.06
custom!
Length
Color
Offset
ISO and DIN dimensions.
Tip! - use the "Rotate Object" bellow to turn the object after it is inserted.
Edit
undo! - redo!
Color
View
Make Component
Rotate Object(s)
Move or Copy Object(s)
The Knife
YouTube demo of the Knife!
Change Insertion Point
Insert Line
red green blue - End position
Insert Horizontal Plane
Insert Vertical Plane
Insert Box
Insert external Component
insert! name url
