Australien AS 2129 Table D plate flanges with flat faces
NB! If there is problem with inserting flanges - reinstall the extension by using alternative 3 as described in the right column.
Nominal Size | Outside Diameter of Flange | Diameter Bore | Thickness of Flange | No. of Holes | Diameter of Holes | Diameter of Bolts | Diameter of Bolt Circle | Weight | |
mm | mm | mm | mm | mm | mm | mm | kg | ||
insert! | 15 | 95 | 22.3 | 5 | 4 | 14 | M12 | 67 | 0.3 |
insert! | 20 | 100 | 27.6 | 5 | 4 | 14 | M12 | 73 | 0.3 |
insert! | 25 | 115 | 34.5 | 5 | 4 | 14 | M12 | 83 | 0.4 |
insert! | 32 | 120 | 43.1 | 6 | 4 | 14 | M12 | 87 | 0.5 |
insert! | 40 | 135 | 49.5 | 6 | 4 | 14 | M12 | 98 | 0.6 |
insert! | 50 | 150 | 61.9 | 8 | 4 | 18 | M16 | 114 | 0.9 |
insert! | 65 | 165 | 74.6 | 8 | 4 | 18 | M16 | 127 | 1.1 |
insert! | 80 | 185 | 90.6 | 10 | 4 | 18 | M16 | 146 | 1.6 |
insert! | 100 | 215 | 116 | 10 | 4 | 18 | M16 | 178 | 2.1 |
insert! | 125 | 255 | 143.7 | 13 | 8 | 18 | M16 | 210 | 3.7 |
insert! | 150 | 280 | 170.6 | 13 | 8 | 18 | M16 | 235 | 4.1 |
insert! | 200 | 335 | 221.4 | 13 | 8 | 18 | M16 | 292 | 5.1 |
insert! | 250 | 405 | 276.3 | 16 | 8 | 22 | M20 | 356 | 8.8 |
insert! | 300 | 455 | 327.1 | 19 | 12 | 22 | M20 | 406 | 11.9 |
insert! | 350 | 525 | 359.1 | 22 | 12 | 22 | M20 | 470 | 20.2 |
insert! | 400 | 580 | 410.4 | 22 | 12 | 26 | M24 | 521 | 23.1 |
insert! | 450 | 640 | 461.7 | 25 | 12 | 26 | M24 | 584 | 30.7 |
insert! | 500 | 705 | 513.0 | 29 | 16 | 26 | M24 | 641 | 42.4 |
insert! | 600 | 825 | 615.9 | 32 | 16 | 30 | M27 | 756 | 60.2 |
custom! |
Tip! - use the "Rotate Object" bellow to turn the object after it is inserted.
undo! redo!
change color!
make!
startpoint
endpoint insert!
It's FREE and FUN!
and more.
3 18
