Australien AS 2129 Table D blind flanges with raised faces
NB! If there is problem with inserting flanges - try to reinstall the extension by using alternative 3 as described in the right column.
Nominal Size | Outside Diameter of Flange | Thickness of Flange | No. of Holes | Diameter of Holes | Diameter of Bolts | Diameter of Bolt Circle | Diameter of Raised Face | Height of Raised Face | Weight | |
mm | mm | mm | mm | mm | mm | mm | mm | kg | ||
insert! | 15 | 95 | 5 | 4 | 14 | M12 | 67 | 47 | 1.6 | 0.3 |
insert! | 20 | 100 | 5 | 4 | 14 | M12 | 73 | 53 | 1.6 | 0.3 |
insert! | 25 | 115 | 5 | 4 | 14 | M12 | 83 | 65 | 1.6 | 0.4 |
insert! | 32 | 120 | 6 | 4 | 14 | M12 | 87 | 67 | 1.6 | 0.5 |
insert! | 40 | 135 | 6 | 4 | 14 | M12 | 98 | 78 | 1.6 | 0.6 |
insert! | 50 | 150 | 8 | 4 | 18 | M16 | 114 | 90 | 1.6 | 0.9 |
insert! | 65 | 165 | 8 | 4 | 18 | M16 | 127 | 103 | 1.6 | 1.1 |
insert! | 80 | 185 | 10 | 4 | 18 | M16 | 146 | 122 | 1.6 | 1.6 |
insert! | 100 | 215 | 10 | 4 | 18 | M16 | 178 | 154 | 1.6 | 2.1 |
insert! | 125 | 255 | 13 | 8 | 18 | M16 | 210 | 186 | 1.6 | 3.7 |
insert! | 150 | 280 | 13 | 8 | 18 | M16 | 235 | 211 | 1.6 | 4.1 |
insert! | 200 | 335 | 13 | 8 | 18 | M16 | 292 | 268 | 1.6 | 5.1 |
insert! | 250 | 405 | 16 | 8 | 22 | M20 | 356 | 328 | 1.6 | 8.8 |
insert! | 300 | 455 | 19 | 12 | 22 | M20 | 406 | 378 | 1.6 | 11.9 |
insert! | 350 | 525 | 22 | 12 | 22 | M20 | 470 | 438 | 1.6 | 20.2 |
insert! | 400 | 580 | 22 | 12 | 26 | M24 | 521 | 489 | 1.6 | 23.1 |
insert! | 450 | 640 | 25 | 12 | 26 | M24 | 584 | 532 | 1.6 | 30.7 |
insert! | 500 | 705 | 29 | 16 | 26 | M24 | 641 | 609 | 1.6 | 42.4 |
insert! | 600 | 825 | 32 | 16 | 30 | M27 | 756 | 720 | 1.6 | 60.2 |
custom! |
Tip! - use the "Rotate Object" bellow to turn the object after it is inserted.
undo! redo!
change color!
make!
startpoint
endpoint insert!
It's FREE and FUN!
and more.
3 18
