Blind flanges ASME B16.5
| Nominal Size | Outside Diameter of Flange | Thickness of Flange | Diameter of Raised Face | Height of Raised Face | No. of Holes | Diameter of Holes | Diameter of Bolts | Diameter of Bolt Circle | Weight | |
| in | in | in | in | in | in | in | in | lbs | ||
| insert! | 1/2 | 4.75 | 0.88 | 1.38 | 0.25 | 4 | 0.88 | 3/4 | 3.25 | 4 |
| insert! | 3/4 | 5.12 | 1 | 1.69 | 0.25 | 4 | 0.88 | 3/4 | 3.5 | 6 |
| insert! | 1 | 5.88 | 1.12 | 2 | 0.25 | 4 | 1 | 7/8 | 4 | 9 |
| insert! | 1 1/4 | 6.25 | 1.12 | 2.5 | 0.25 | 4 | 1 | 7/8 | 4.38 | 10 |
| insert! | 1 1/2 | 7 | 1.25 | 2.88 | 0.25 | 4 | 1.12 | 1 | 4.88 | 14 |
| insert! | 2 | 8.5 | 1.5 | 3.62 | 0.25 | 8 | 1 | 7/8 | 6.5 | 25 |
| insert! | 2 1/2 | 9.62 | 1.62 | 4.12 | 0.25 | 8 | 1.12 | 1 | 7.5 | 35 |
| insert! | 3 | 9.5 | 1.5 | 5 | 0.25 | 8 | 1 | 7/8 | 7.5 | 32 |
| insert! | 4 | 11.5 | 1.75 | 6.19 | 0.25 | 8 | 1.25 | 1 1/8 | 9.25 | 54 |
| insert! | 5 | 13.75 | 2 | 7.31 | 0.25 | 8 | 1.38 | 1 1/4 | 11 | 87 |
| insert! | 6 | 15 | 2.19 | 8.5 | 0.25 | 12 | 1.25 | 1 1/8 | 12.5 | 113 |
| insert! | 8 | 18.5 | 2.5 | 10.62 | 0.25 | 12 | 1.5 | 1 3/8 | 15.5 | 197 |
| insert! | 10 | 21.5 | 2.75 | 12.75 | 0.25 | 16 | 1.5 | 1 3/8 | 18.5 | 290 |
| insert! | 12 | 24 | 3.12 | 15 | 0.25 | 20 | 1.5 | 1 3/8 | 21 | 413 |
| insert! | 14 | 25.25 | 3.38 | 16.25 | 0.25 | 20 | 1.62 | 1 1/2 | 22 | 494 |
| insert! | 16 | 27.75 | 3.5 | 18.5 | 0.25 | 20 | 1.75 | 1 5/8 | 24.25 | 619 |
| insert! | 18 | 31 | 4 | 21 | 0.25 | 20 | 2 | 1 7/8 | 27 | 880 |
| insert! | 20 | 33.75 | 4.25 | 23 | 0.25 | 20 | 2.12 | 2 | 29.5 | 1107 |
| insert! | 24 | 41 | 5.5 | 27.25 | 0.25 | 20 | 2.62 | 2 1/2 | 35.5 | 2099 |
| custom! | ||||||||||
Edit:
undo -
redo
Color:
change color!
View:
iso -
top -
front -
right -
left -
back -
bottom
Make Component:
Rotate Object(s):
degrees around
red,
green or
blue
move/copy!
no. copies
red
green
blue
with multiple copies.
move!
New! Change Insertion Point
red
green
blue
- Start position
red
green
blue
- End position
insert!
insert!
red (size)
green (size)
blue (vertical position)
insert!
red (horizontal position)
green (size)
blue (vertical size)
insert!
red (size)
green (horizontal position)
Insert Box: - add a box
insert!
red (width)
green (depth)
blue (height)
insert!
name
url
10 3 22
It's FREE and
it's FUN!
Download
engineeringtoolbox.rb
Exit and reload SketchUp!
or
(Mac)
(Mac users look here!)
add components to the
groups!
on Mac computers.
