Home  > Piping  > Flanges  >
DIN 2635 Welding Neck Flanges PN40/40BAR
Dimensions, sizes and specifications of DIN 2635 Welding Neck Flanges PN40/40BAR
Nominal Size Outside Diameter of Flange Diameter Bore Thickness of Flange Diameter of Raised Face Height of Raised Face Diameter of Hub at Base Diameter of Hub at Point of Welding Length through Hub No. of Holes Diameter of Holes Diameter of Bolts Diameter of Bolt Circle Weight
mm mm mm mm mm mm mm mm mm mm mm mm kg
insert! 10 90 10.4 16 40 2 25 14 35 4 14 60 0.67
insert! 10 90 13.6 16 40 2 28 17.2 35 4 14 60 0.66
insert! 15 95 16 16 45 2 30 20 38 4 14 65 0.75
insert! 15 95 17.3 16 45 2 32 21.3 38 4 14 65 0.75
insert! 20 105 20.4 18 58 2 48 25 40 4 14 75 1.07
insert! 20 105 22.3 18 58 2 40 26.9 40 4 14 75 1.07
insert! 25 115 24.8 18 68 2 42 30 40 4 14 85 1.29
insert! 25 115 28.5 18 68 2 46 33.7 40 4 14 85 1.28
insert! 32 140 32.8 18 78 2 52 38 42 4 18 100 1.88
insert! 32 140 37.2 18 78 2 56 42.4 42 4 18 100 1.86
insert! 40 150 39.3 18 88 3 60 44.5 45 4 18 110 2.1
insert! 40 150 43.1 18 88 3 64 48.3 45 4 18 110 2.08
insert! 50 165 51.2 20 102 3 72 57 48 4 18 125 2.81
insert! 50 165 54.5 20 102 3 75 60.3 48 4 18 125 2.78
insert! 65 185 70.3 22 122 3 90 76.1 52 8 18 145 3.81
insert! 80 200 82.5 24 138 3 105 88.9 58 8 18 160 4.62
insert! 100 235 100.4 24 162 3 128 108 65 8 22 190 6.42
insert! 100 235 107.1 24 162 3 134 114.3 65 8 22 190 6.27
insert! 125 270 125 26 188 3 155 133 68 8 26 220 8.83
insert! 125 270 131.7 26 188 3 162 139.7 68 8 26 220 8.61
insert! 150 300 150 28 218 3 182 159 75 8 26 250 11.67
insert! 150 300 159.3 28 218 3 192 168.3 75 8 26 250 11.29
insert! 175 350 182.5 32 260 3 218 193.7 82 12 30 295 17.01
insert! 200 375 206.5 34 285 3 244 219.1 88 12 30 320 20.49
insert! 250 450 252.8 38 345 3 298 267 105 12 33 385 33.75
insert! 250 450 258.8 38 345 3 306 273 105 12 33 385 33.34
insert! 300 515 307.9 42 410 4 362 323.9 115 16 33 450 46.55
insert! 350 580 338 46 465 4 408 355.6 125 16 36 510 67.73
insert! 350 580 350.4 46 465 4 408 368 125 16 36 510 63.96
insert! 400 660 384.4 50 535 4 462 406.4 135 16 39 585 96.73
insert! 400 660 397 50 535 4 462 419 135 16 39 585 91.99
insert! 500 755 479.6 52 615 4 562 508 140 20 42 670 120.96
custom!
Length
Color
Offset
ISO and DIN dimensions.
Edit
undo! - redo!
Color
View
Make Component
Rotate Object(s)
Move or Copy Object(s)
The Knife
YouTube demo of the Knife!
Change Insertion Point
Insert Line
red green blue - End position
Insert Horizontal Plane
Insert Vertical Plane
Insert Box
Insert external Component
insert! name url
