Home  > Piping  > Flanges  >
DIN 2503 Plate Flanges PN25
Dimension and weight of DIN 2503 Plate Flanges PN25
DIN 2503 Plate Flange PN25
Nominal Size Outside Diameter of Flange Diameter Bore Thickness of Flange No. of Holes Diameter of Holes Diameter of Bolts Diameter of Bolt Circle Weight
mm mm mm mm mm mm mm kg
insert! 10 90 14.5 16 4 14 60 0.7
insert! 10 90 17.7 16 4 14 60 0.69
insert! 15 95 21 16 4 14 65 0.77
insert! 15 95 22 16 4 14 65 0.77
insert! 20 105 26 18 4 14 75 1.06
insert! 20 105 27.6 18 4 14 75 1.05
insert! 25 115 31 18 4 14 85 1.27
insert! 25 115 34.4 18 4 14 85 1.25
insert! 32 140 39 18 4 18 100 1.86
insert! 32 140 43.1 18 4 18 100 1.83
insert! 40 150 45.5 18 4 18 110 2.12
insert! 40 150 49 18 4 18 110 2.09
insert! 50 165 58.1 20 4 18 125 2.78
insert! 50 165 61.1 20 4 18 125 2.74
insert! 65 185 77.1 22 8 18 145 3.48
insert! 80 200 90.3 24 8 18 160 4.33
insert! 100 235 109.6 24 8 22 190 5.82
insert! 100 235 115.9 24 8 22 190 5.61
insert! 125 270 134.8 26 8 26 220 7.91
insert! 125 270 141.6 26 8 26 220 7.6
insert! 150 300 161.1 28 8 26 250 10.12
insert! 150 300 170.5 28 8 26 250 9.58
insert! 175 330 196.1 28 12 26 280 10.76
insert! 200 360 221.8 30 12 26 310 13.37
insert! 250 425 270.2 32 12 30 370 19.1
insert! 250 425 276.2 32 12 30 370 18.45
insert! 300 485 327.6 34 16 30 430 23.79
insert! 350 555 359.7 38 16 33 490 37.77
insert! 350 555 372.2 38 16 33 490 35.63
insert! 400 620 411 40 16 36 550 48.03
insert! 400 620 423.7 40 16 36 550 45.41
insert! 500 730 513.6 44 20 36 660 65.97
insert! 600 845 616.5 50 20 39 770 93.57
insert! 700 960 716 52 24 42 875 117.53
insert! 800 1085 818 56 24 48 990 156.34
insert! 900 1185 920 62 28 48 1090 188.57
insert! 1000 1320 1022 68 28 56 1210 255.79
custom!
Length
Color
Offset
ISO Series 1 and DIN Series 2
Tip! - use the "Rotate Object" bellow to turn the object after it is inserted.
Edit
undo! - redo!
Color
View
Make Component
Rotate Object(s)
Move or Copy Object(s)
The Knife
YouTube demo of the Knife!
Change Insertion Point
Insert Line
red green blue - End position
Insert Horizontal Plane
Insert Vertical Plane
Insert Box
Insert external Component
insert! name url
