Dimensions, sizes and specifications of EN 1092-1 Type 11 Welding Neck Flanges PN16/16BAR
NB! If there is problem with inserting flanges - try to reinstall the extension by using alternative 3 as described in the right column.
Nominal Size - DN | Outside Diameter of Flange - D | Diameter of Bolt Circle - K | Diameter of Bolt Hole - L | Bolting Number | Bolting Size | Outside Diameter of Neck - A | Flange Thickness - C2 | Length - H2 | Neck Diameters - N1 | Wall Thickness - S | |
mm | mm | mm | mm | mm | mm | mm | mm | mm | |||
insert! | 10 | 90 | 60 | 14 | 4 | M12 | 17.2 | 16 | 35 | 28 | 2 |
insert! | 15 | 95 | 65 | 14 | 4 | M12 | 21.3 | 16 | 38 | 32 | 2 |
insert! | 20 | 105 | 75 | 14 | 4 | M12 | 26.9 | 18 | 40 | 40 | 2.3 |
insert! | 25 | 115 | 85 | 14 | 4 | M12 | 33.7 | 18 | 40 | 46 | 2.6 |
insert! | 32 | 140 | 100 | 18 | 4 | M16 | 42.4 | 18 | 42 | 56 | 2.6 |
insert! | 40 | 150 | 110 | 18 | 4 | M16 | 48.3 | 18 | 45 | 64 | 2.6 |
insert! | 50 | 165 | 125 | 18 | 4 | M16 | 60.3 | 18 | 45 | 74 | 2.9 |
insert! | 65 | 185 | 145 | 18 | 8 | M16 | 76.1 | 18 | 45 | 92 | 2.9 |
insert! | 80 | 200 | 160 | 18 | 8 | M16 | 88.9 | 20 | 50 | 105 | 3.2 |
insert! | 100 | 220 | 180 | 18 | 8 | M16 | 114.3 | 20 | 52 | 131 | 3.6 |
insert! | 125 | 250 | 210 | 18 | 8 | M16 | 139.7 | 22 | 55 | 156 | 4 |
insert! | 150 | 285 | 240 | 22 | 8 | M20 | 168.3 | 22 | 55 | 184 | 4.5 |
insert! | 200 | 340 | 295 | 22 | 8 | M20 | 219.1 | 24 | 62 | 234 | 6.3 |
insert! | 250 | 405 | 355 | 26 | 12 | M24 | 273.0 | 26 | 70 | 292 | 6.3 |
insert! | 300 | 460 | 410 | 26 | 12 | M24 | 323.9 | 28 | 78 | 344 | 7.1 |
insert! | 350 | 520 | 470 | 26 | 16 | M24 | 355.6 | 30 | 82 | 390 | 8.0 |
insert! | 400 | 580 | 525 | 30 | 16 | M27 | 406.4 | 32 | 85 | 445 | 8.0 |
insert! | 450 | 640 | 585 | 30 | 20 | M27 | 457 | 34 | 83 | 490 | 8.0 |
insert! | 500 | 715 | 650 | 33 | 20 | M30 | 508 | 36 | 84 | 548 | 8.0 |
insert! | 600 | 840 | 770 | 36 | 20 | M33 | 610 | 40 | 88 | 670 | 10.0 |
insert! | 700 | 910 | 840 | 36 | 24 | M33 | 711 | 40 | 104 | 755 | 10.0 |
insert! | 800 | 1025 | 950 | 39 | 24 | M36 | 813 | 41 | 108 | 855 | 12.5 |
insert! | 900 | 1125 | 1050 | 39 | 28 | M36 | 914 | 48 | 118 | 955 | 12.5 |
insert! | 1000 | 1255 | 1170 | 42 | 28 | M39 | 1016 | 59 | 137 | 1058 | 12.5 |
insert! | 1200 | 1485 | 1390 | 48 | 32 | M45 | 1219 | 78 | 160 | 1262 | 14.2 |
insert! | 1400 | 1685 | 1560 | 48 | 36 | M45 | 1422 | 84 | 177 | 1465 | 16.0 |
insert! | 1600 | 1930 | 1820 | 56 | 40 | M52 | 1626 | 102 | 204 | 1668 | 17.5 |
insert! | 1800 | 2130 | 2020 | 56 | 44 | M52 | 1829 | 110 | 218 | 1870 | 20.0 |
insert! | 2000 | 2345 | 2230 | 62 | 48 | M56 | 2032 | 124 | 238 | 2072 | 22.0 |
custom! |
Tip! - use the "Rotate Object" bellow to turn the object after it is inserted.
undo! redo!
change color!
make!
startpoint
endpoint insert!
It's FREE and FUN!
and more.
3 18
