Dimensions, sizes and specifications of DIN 2637 Welding Neck Flanges PN100/100BAR
NB! If there is problem with inserting flanges - try to reinstall the extension by using alternative 3 as described in the right column.
Nominal Size | Outside Diameter of Flange | Diameter Bore | Thickness of Flange | Diameter of Raised Face | Height of Raised Face | Diameter of Hub at Base | Diameter of Hub at Point of Welding | Length through Hub | No. of Holes | Diameter of Holes | Diameter of Bolts | Diameter of Bolt Circle | Weight | |
mm | mm | mm | mm | mm | mm | mm | mm | mm | mm | mm | mm | kg | ||
insert! | 10 | 100 | 10.4 | 20 | 40 | 2 | 28 | 14 | 45 | 4 | 14 | 70 | 1.07 | |
insert! | 10 | 100 | 13.6 | 20 | 40 | 2 | 32 | 17.2 | 45 | 4 | 14 | 70 | 1.08 | |
insert! | 15 | 105 | 16 | 20 | 45 | 2 | 32 | 20 | 45 | 4 | 14 | 75 | 1.19 | |
insert! | 15 | 105 | 17.3 | 20 | 45 | 2 | 34 | 21.3 | 45 | 4 | 14 | 75 | 1.19 | |
insert! | 25 | 140 | 24.8 | 24 | 68 | 2 | 48 | 30 | 58 | 4 | 18 | 100 | 2.61 | |
insert! | 25 | 140 | 28.5 | 24 | 68 | 2 | 52 | 33.7 | 58 | 4 | 18 | 100 | 2.6 | |
insert! | 40 | 170 | 38.7 | 26 | 88 | 3 | 65 | 44.5 | 62 | 4 | 22 | 125 | 4 | |
insert! | 40 | 170 | 42.5 | 26 | 88 | 3 | 70 | 48.3 | 62 | 4 | 22 | 125 | 3.99 | |
insert! | 50 | 195 | 50.6 | 28 | 102 | 3 | 86 | 57 | 68 | 4 | 26 | 145 | 5.72 | |
insert! | 50 | 195 | 53.9 | 28 | 102 | 3 | 90 | 60.3 | 68 | 4 | 26 | 145 | 5.7 | |
insert! | 65 | 220 | 68.9 | 30 | 122 | 3 | 108 | 76.1 | 76 | 8 | 26 | 170 | 7.43 | |
insert! | 80 | 230 | 80.9 | 32 | 138 | 3 | 120 | 88.9 | 78 | 8 | 26 | 180 | 8.58 | |
insert! | 100 | 265 | 98 | 36 | 162 | 3 | 145 | 108 | 90 | 8 | 30 | 210 | 13.02 | |
insert! | 100 | 265 | 104.3 | 36 | 162 | 3 | 150 | 114.3 | 90 | 8 | 30 | 210 | 12.79 | |
insert! | 125 | 315 | 120.4 | 40 | 188 | 3 | 180 | 133 | 105 | 8 | 33 | 250 | 21.29 | |
insert! | 125 | 315 | 127.1 | 40 | 188 | 3 | 180 | 139.7 | 105 | 8 | 33 | 250 | 20.68 | |
insert! | 150 | 355 | 144.8 | 44 | 218 | 3 | 210 | 159 | 115 | 12 | 33 | 290 | 28.9 | |
insert! | 150 | 355 | 154.1 | 44 | 218 | 3 | 210 | 168.3 | 115 | 12 | 33 | 290 | 27.76 | |
insert! | 175 | 385 | 176.1 | 48 | 260 | 3 | 245 | 193.7 | 127 | 12 | 33 | 320 | 36.94 | |
insert! | 200 | 430 | 199.1 | 52 | 285 | 3 | 278 | 219.1 | 130 | 12 | 36 | 360 | 49.35 | |
insert! | 250 | 505 | 242 | 60 | 345 | 3 | 340 | 267 | 157 | 12 | 39 | 430 | 81.71 | |
insert! | 250 | 505 | 248 | 60 | 345 | 3 | 340 | 273 | 157 | 12 | 39 | 430 | 80.09 | |
insert! | 300 | 585 | 295.5 | 68 | 410 | 4 | 400 | 323.9 | 170 | 16 | 42 | 500 | 116.25 | |
insert! | 350 | 655 | 323.6 | 74 | 465 | 4 | 460 | 355.6 | 189 | 16 | 48 | 560 | 166.09 | |
insert! | 350 | 655 | 336 | 74 | 465 | 4 | 460 | 368 | 189 | 16 | 48 | 560 | 160.53 | |
insert! | 400 | 670 | 378 | 60 | 535 | 4 | 475 | 406.4 | 160 | 16 | 42 | 585 | 127.7 | |
insert! | 400 | 670 | 390.6 | 60 | 535 | 4 | 475 | 419 | 160 | 16 | 42 | 585 | 122.13 | |
insert! | 350 | 580 | 338 | 46 | 465 | 4 | 408 | 355.6 | 125 | 16 | 36 | 510 | 67.73 | |
insert! | 350 | 580 | 350.4 | 46 | 465 | 4 | 408 | 368 | 125 | 16 | 36 | 510 | 63.96 | |
custom! |
ISO and DIN dimensions.
Tip! - use the "Rotate Object" bellow to turn the object after it is inserted.
undo! redo!
change color!
make!
startpoint
endpoint insert!
It's FREE and FUN!
and more.
3 18
