Blind flanges ASME B16.5
| Nominal Size | Outside Diameter of Flange | Thickness of Flange | Diameter of Raised Face | Height of Raised Face | No. of Holes | Diameter of Holes | Diameter of Bolts | Diameter of Bolt Circle | Weight | |
| in | in | in | in | in | in | in | in | lbs | ||
| insert! | 1/2 | 4.75 | 0.88 | 1.38 | 0.25 | 4 | 0.88 | 3/4 | 3.25 | 4 |
| insert! | 3/4 | 5.12 | 1 | 1.69 | 0.25 | 4 | 0.88 | 3/4 | 3.5 | 6 |
| insert! | 1 | 5.88 | 1.12 | 2 | 0.25 | 4 | 1 | 7/8 | 4 | 9 |
| insert! | 1 1/4 | 6.25 | 1.12 | 2.5 | 0.25 | 4 | 1 | 7/8 | 4.38 | 10 |
| insert! | 1 1/2 | 7 | 1.25 | 2.88 | 0.25 | 4 | 1.12 | 1 | 4.88 | 14 |
| insert! | 2 | 8.5 | 1.5 | 3.62 | 0.25 | 8 | 1 | 7/8 | 6.5 | 25 |
| insert! | 2 1/2 | 9.62 | 1.62 | 4.12 | 0.25 | 8 | 1.12 | 1 | 7.5 | 35 |
| insert! | 3 | 10.5 | 1.88 | 5 | 0.25 | 8 | 1.25 | 1 1/8 | 8 | 48 |
| insert! | 4 | 12.25 | 2.12 | 6.19 | 0.25 | 8 | 1.38 | 1 1/4 | 9.5 | 73 |
| insert! | 5 | 14.75 | 2.88 | 7.31 | 0.25 | 8 | 1.62 | 1 1/2 | 11.5 | 142 |
| insert! | 6 | 15.5 | 3.25 | 8.5 | 0.25 | 12 | 1.5 | 1 3/8 | 12.5 | 159 |
| insert! | 8 | 19 | 3.62 | 10.62 | 0.25 | 12 | 1.75 | 1 5/8 | 15.5 | 302 |
| insert! | 10 | 23 | 4.25 | 12.75 | 0.25 | 12 | 2 | 1 7/8 | 19 | 507 |
| insert! | 12 | 26.5 | 4.88 | 15 | 0.25 | 16 | 2.12 | 2 | 22.5 | 775 |
| insert! | 14 | 29.5 | 5.25 | 16.25 | 0.25 | 16 | 2.38 | 2 1/4 | 25 | |
| insert! | 16 | 32.5 | 5.75 | 18.5 | 0.25 | 16 | 2.62 | 2 1/2 | 27.75 | |
| insert! | 18 | 36 | 6.38 | 21 | 0.25 | 16 | 2.88 | 2 3/4 | 30.5 | |
| insert! | 20 | 38.75 | 7 | 23 | 0.25 | 16 | 3.12 | 3 | 32.75 | |
| insert! | 24 | 46 | 8 | 27.25 | 0.25 | 16 | 3.62 | 3 1/2 | 39 | |
| custom! | ||||||||||
Edit:
undo -
redo
Color:
change color!
View:
iso -
top -
front -
right -
left -
back -
bottom
Make Component:
Rotate Object(s):
degrees around
red,
green or
blue
move/copy!
no. copies
red
green
blue
with multiple copies.
move!
New! Change Insertion Point
red
green
blue
- Start position
red
green
blue
- End position
insert!
insert!
red (size)
green (size)
blue (vertical position)
insert!
red (horizontal position)
green (size)
blue (vertical size)
insert!
red (size)
green (horizontal position)
Insert Box: - add a box
insert!
red (width)
green (depth)
blue (height)
insert!
name
url
10 3 20
It's FREE and
it's FUN!
Download
engineeringtoolbox.rb
Exit and reload SketchUp!
or
(Mac)
(Mac users look here!)
add components to the
groups!
on Mac computers.
