Blind flanges ASME B16.5 - 400 lbs
| Nominal Size | Outside Diameter of Flange | Thickness of Flange | Diameter of Raised Face | Height of Raised Face | No. of Holes | Diameter of Holes | Diameter of Bolts | Diameter of Bolt Circle | Weight | |
| in | in | in | in | in | in | in | in | lbs | ||
| insert! | 1/2 | 3.75 | 0.56 | 1.38 | 0.25 | 4 | 0.62 | 1/2 | 2.62 | 2 |
| insert! | 3/4 | 4.62 | 0.62 | 1.69 | 0.25 | 4 | 0.75 | 5/8 | 3.25 | 3 |
| insert! | 1 | 4.88 | 0.69 | 2 | 0.25 | 4 | 0.75 | 5/8 | 3.5 | 4 |
| insert! | 1 1/4 | 5.25 | 0.81 | 2.5 | 0.25 | 4 | 0.75 | 5/8 | 3.88 | 6 |
| insert! | 1 1/2 | 6.12 | 0.88 | 2.88 | 0.25 | 4 | 0.88 | 3/4 | 4.5 | 8 |
| insert! | 2 | 6.5 | 1 | 3.62 | 0.25 | 8 | 0.75 | 5/8 | 5 | 10 |
| insert! | 2 1/2 | 7.5 | 1.12 | 4.12 | 0.25 | 8 | 0.88 | 3/4 | 5.88 | 15 |
| insert! | 3 | 8.25 | 1.25 | 5 | 0.25 | 8 | 0.88 | 3/4 | 6.62 | 20 |
| insert! | 3 1/2 | 9 | 1.38 | 5.5 | 0.25 | 8 | 1 | 7/8 | 7.25 | 29 |
| insert! | 4 | 10 | 1.38 | 6.19 | 0.25 | 8 | 1 | 7/8 | 7.88 | 33 |
| insert! | 5 | 11 | 1.5 | 7.31 | 0.25 | 8 | 1 | 7/8 | 9.25 | 44 |
| insert! | 6 | 12.5 | 1.62 | 8.5 | 0.25 | 12 | 1 | 7/8 | 10.62 | 61 |
| insert! | 8 | 15 | 1.88 | 10.62 | 0.25 | 12 | 1.12 | 1 | 13 | 100 |
| insert! | 10 | 17.5 | 2.12 | 12.75 | 0.25 | 16 | 1.25 | 1 1/8 | 15.25 | 155 |
| insert! | 12 | 20.5 | 2.25 | 15 | 0.25 | 16 | 1.38 | 1 1/4 | 17.75 | 226 |
| insert! | 14 | 23 | 2.38 | 16.25 | 0.25 | 20 | 1.38 | 1 1/4 | 20.25 | 310 |
| insert! | 16 | 25.5 | 2.5 | 18.5 | 0.25 | 20 | 1.5 | 1 3/8 | 22.5 | 398 |
| insert! | 18 | 28 | 2.62 | 21 | 0.25 | 24 | 1.5 | 1 3/8 | 24.75 | 502 |
| insert! | 20 | 30.5 | 2.75 | 23 | 0.25 | 24 | 1.62 | 1 1/2 | 27 | 621 |
| insert! | 24 | 36 | 3 | 27.25 | 0.25 | 24 | 1.88 | 1 3/4 | 32 | 936 |
| custom! | ||||||||||
Edit:
undo -
redo
Color:
change color!
View:
iso -
top -
front -
right -
left -
back -
bottom
Make Component:
Rotate Object(s):
degrees around
red,
green or
blue
move/copy!
no. copies
red
green
blue
with multiple copies.
move!
New! Change Insertion Point
red
green
blue
- Start position
red
green
blue
- End position
insert!
insert!
red (size)
green (size)
blue (vertical position)
insert!
red (horizontal position)
green (size)
blue (vertical size)
insert!
red (size)
green (horizontal position)
Insert Box: - add a box
insert!
red (width)
green (depth)
blue (height)
insert!
name
url
10 3 22
It's FREE and
it's FUN!
Download
engineeringtoolbox.rb
Exit and reload SketchUp!
or
(Mac)
(Mac users look here!)
add components to the
groups!
on Mac computers.
