Home  > Piping  > Flanges  >
DIN 2573 Plate Flanges PN6
Dimension and weight of DIN2573 PN6 Plate Flange
Nominal Size Outside Diameter of Flange Diameter Bore Thickness of Flange No. of Holes Diameter of Holes Diameter of Bolts Diameter of Bolt Circle Weight
mm mm mm mm mm mm mm kg
insert! 10 75 14.5 12 4 11 50 0.36
insert! 10 75 17.7 12 4 11 50 0.36
insert! 15 80 21 12 4 11 55 0.41
insert! 15 80 22 12 4 11 55 0.4
insert! 20 90 26 14 4 11 65 0.6
insert! 20 90 27.6 14 4 11 65 0.59
insert! 25 100 31 14 4 11 75 0.74
insert! 25 100 34.4 14 4 11 75 0.72
insert! 32 120 39 16 4 14 90 1.19
insert! 32 120 43.1 16 4 14 90 1.16
insert! 40 130 45.5 16 4 14 100 1.39
insert! 40 130 49 16 4 14 100 1.35
insert! 50 140 58.1 16 4 14 110 1.52
insert! 50 140 61.1 16 4 14 110 1.49
insert! 65 160 77.1 16 4 14 130 1.86
insert! 80 190 90.3 18 4 14 150 2.96
insert! 100 210 109.6 18 4 18 170 3.42
insert! 100 210 115.9 18 4 18 170 3.26
insert! 125 240 134.8 20 8 18 200 4.54
insert! 125 240 141.6 20 8 18 200 4.31
insert! 150 265 161.1 20 8 18 225 5.34
insert! 150 265 170.5 20 8 18 225 4.76
insert! 200 320 221.8 22 8 18 280 6.87
insert! 250 325 270.2 24 12 18 335 9.42
insert! 250 325 276.2 24 12 18 335 8.94
insert! 300 440 327.6 24 12 22 395 11.91
insert! 350 480 359.7 26 12 22 445 16.52
insert! 350 490 372.2 26 12 22 445 15.35
insert! 400 540 411 28 16 22 495 18.84
insert! 400 540 423.7 28 16 22 495 18.01
insert! 450 595 462.3 30 16 22 550 24.52
insert! 500 645 513.6 30 20 22 600 26.37
custom!
Length
Color
Offset
ISO Series 1 and DIN Series 2
Edit
undo! - redo!
Color
View
Make Component
Rotate Object(s)
Move or Copy Object(s)
The Knife
YouTube demo of the Knife!
Change Insertion Point
Insert Line
red green blue - End position
Insert Horizontal Plane
Insert Vertical Plane
Insert Box
Insert external Component
insert! name url
