Home  > Piping  > Flanges  >
DIN 2634 Welding Neck Flanges PN25/25BAR
Dimensions, sizes and specifications of DIN 2634 Welding Neck Flanges PN25/25BAR
Nominal Size Outside Diameter of Flange Diameter Bore Thickness of Flange Diameter of Raised Face Height of Raised Face Diameter of Hub at Base Diameter of Hub at Point of Welding Length through Hub No. of Holes Diameter of Holes Diameter of Bolts Diameter of Bolt Circle Weight
mm mm mm mm mm mm mm mm mm mm mm mm kg
insert! 10 90 10.4 16 40 2 25 14 35 4 14 60 0.67
insert! 10 90 13.6 16 40 2 28 17.2 35 4 14 60 0.66
insert! 15 95 16 16 45 2 30 20 38 4 14 65 0.75
insert! 15 95 17.3 16 45 2 32 21.3 38 4 14 65 0.75
insert! 20 105 20.4 18 58 2 38 25 40 4 14 75 1.07
insert! 20 105 22.3 18 58 2 40 26.9 40 4 14 75 1.07
insert! 25 115 24.8 18 68 2 42 30 40 4 14 85 1.29
insert! 25 115 28.5 18 68 2 46 33.7 40 4 14 85 1.28
insert! 32 140 32.8 18 78 2 52 38 42 4 18 100 1.88
insert! 32 140 37.2 18 78 2 56 42.4 42 4 18 100 1.86
insert! 40 150 39.3 18 88 3 60 44.5 45 4 18 110 2.1
insert! 40 150 43.1 18 88 3 64 48.3 45 4 18 110 2.08
insert! 50 165 51.2 20 102 3 72 57 48 4 18 125 2.81
insert! 50 165 54.5 20 102 3 75 60.3 48 4 18 125 2.78
insert! 65 185 70.3 22 122 3 90 76.1 52 8 18 145 3.61
insert! 80 200 82.5 24 138 3 105 88.9 58 8 18 160 4.62
insert! 100 235 98.8 24 162 3 128 106 65 8 22 190 6.42
insert! 100 235 107.1 24 162 3 134 114.3 65 8 22 190 6.27
insert! 125 270 125 26 188 3 155 133 68 8 26 220 8.83
insert! 125 270 131.7 26 188 3 162 139.7 68 8 26 220 8.61
insert! 150 300 150 28 218 3 182 159 75 8 26 250 11.67
insert! 150 300 157.3 28 218 3 192 166.3 75 8 26 250 11.29
insert! 175 330 182.5 28 248 3 218 193.7 75 12 26 280 13.11
insert! 200 360 206.5 30 278 3 244 219.1 80 12 26 310 16.61
insert! 250 425 252.8 32 335 3 292 267 88 12 30 370 23.99
insert! 250 425 258.8 32 335 3 298 273 88 12 30 370 23.48
insert! 300 485 307.9 34 395 4 352 323.9 92 16 30 430 30.74
insert! 350 555 339.6 38 450 4 398 355.6 100 16 33 490 47.2
insert! 350 555 352 38 450 4 398 368 100 16 33 490 44.22
insert! 400 620 388.8 40 505 4 452 406.4 110 16 36 550 61.69
insert! 400 620 401.4 40 505 4 452 419 110 16 36 550 57.88
insert! 500 730 488 44 615 4 558 508 125 20 36 660 89.57
insert! 600 845 588 46 720 5 660 610 125 20 39 770 114.96
insert! 700 960 686 46 820 5 760 711 125 24 42 875 139.5
insert! 800 1085 784.6 50 930 5 865 813 135 24 48 990 188.71
insert! 900 1185 882 54 1030 5 968 914 145 28 48 1090 231.48
insert! 1000 1320 981 58 1140 5 1070 1016 155 28 56 1210 303.52
insert! 1200 1485 1195 48 1330 5 1262 1220 130 32 48 1390 244.15
insert! 1400 1685 1391.6 52 1530 5 1465 1420 145 36 48 1590 320.87
insert! 1600 1930 1588 58 1750 5 1668 1620 160 40 56 1820 465.83
insert! 1800 2130 1785 62 1950 5 1870 1820 170 44 56 2020 570.52
insert! 2000 2345 1980 66 2150 5 2072 2020 180 48 62 2230 706.74
custom!
Length
Color
Offset
ISO and DIN dimensions.
Edit
undo! - redo!
Color
View
Make Component
Rotate Object(s)
Move or Copy Object(s)
The Knife
YouTube demo of the Knife!
Change Insertion Point
Insert Line
red green blue - End position
Insert Horizontal Plane
Insert Vertical Plane
Insert Box
Insert external Component
insert! name url
