Sign in!
Home > Piping > Flanges >
ASME B16.5 - Blind Flanges - 150 lbs
Blind flanges ASME B16.5
blind flange 150 lbs
Nominal SizeOutside Diameter of FlangeThickness of FlangeDiameter of Raised FaceHeight of Raised FaceNo. of HolesDiameter of HolesDiameter of BoltsDiameter of Bolt CircleWeight
ininininininininlbs
insert!1/23.50.441.380.062540.621/22.382
insert!3/43.880.51.690.062540.621/22.752
insert!14.250.562.00.062540.621/23.122
insert!1 1/44.620.622.50.062540.621/23.53
insert!1 1/250.692.880.062540.621/23.883
insert!260.753.620.062540.755/84.754
insert!2 1/270.884.120.062540.755/85.57
insert!37.50.9450.062540.755/869
insert!3 1/28.50.945.50.062580.755/8713
insert!490.946.190.062580.755/87.517
insert!5100.947.310.062580.883/48.520
insert!61118.50.062580.883/49.527
insert!813.51.1210.620.062580.883/411.7547
insert!10161.1912.750.06251217/814.2567
insert!12191.25150.06251217/817123
insert!14211.3816.250.0625121.12118.75139
insert!1623.51.4418.50.0625161.12121.25187
insert!18251.56210.0625161.251 1/822.75217
insert!2027.51.69230.0625201.251 1/825283
insert!24321.8827.250.0625201.381 1/429.5415
custom!
ininininininininlbs
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
10 9 3
