Sign in!
Home > Piping > Flanges >
ASME B16.5 WN - Welding Neck Flanges - 900 lbs
Welding Neck ASME B16.5 FLanges 900 lbs
welding neck flange 900 lbs
Nominal SizeOutside Diameter of FlangeDiameter BoreThickness of FlangeDiameter of Raised FaceHeight of Raised FaceDiameter of Hub at BaseDiameter of Hub at Point of WeldingLength through HubNo. of HolesDiameter of HolesDiameter of BoltsDiameter of Bolt CircleWeight
ininininininininininininlbs
insert!1/24.750.550.881.380.251.50.842.3840.883/43.255
insert!3/45.120.7411.690.251.751.052.7540.883/43.56
insert!15.880.961.1220.252.061.322.88417/849
insert!1 1/46.251.281.122.50.252.51.662.88417/84.3810
insert!1 1/271.51.252.880.252.751.93.2541.1214.8813
insert!28.51.941.53.620.254.122.384817/86.525
insert!2 1/29.622.311.624.120.254.882.884.1281.1217.536
insert!39.52.91.550.2553.54817/87.531
insert!411.53.831.756.190.256.254.54.581.251 1/89.2553
insert!513.754.8127.310.257.55.56581.381 1/41186
insert!6155.752.198.50.259.256.635.5121.251 1/812.5110
insert!818.57.632.510.620.2511.758.636.38121.51 3/815.5175
insert!1021.59.752.7512.750.2514.510.757.25161.51 3/818.5260
insert!122411.753.12150.2516.512.757.88201.51 3/821325
insert!1425.25133.3816.250.2517.75148.38201.621 1/222400
insert!1627.75153.518.50.2520168.5201.751 5/824.25495
insert!1831174210.2522.251892021 7/827680
insert!2033.75194.25230.2524.5209.75202.12229.5830
insert!2441235.527.250.2529.52411.5202.622 1/235.51500
custom!
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
10 3 21
