Dimensions, sizes and specifications of EN 1092-1 Type 11 Welding Neck Flanges PN10/10BAR
NB! If there is problem with inserting flanges - try to reinstall the extension by using alternative 3 as described in the right column.
Nominal Size - DN | Outside Diameter of Flange - D | Diameter of Bolt Circle - K | Diameter of Bolt Hole - L | Bolting Number | Bolting Size | Outside Diameter of Neck - A | Flange Thickness - C2 | Length - H2 | Neck Diameters - N1 | Wall Thickness - S | |
mm | mm | mm | mm | mm | mm | mm | mm | mm | |||
insert! | 10 | 90 | 60 | 14 | 4 | M12 | 17.2 | 16 | 35 | 28 | 2 |
insert! | 15 | 95 | 65 | 14 | 4 | M12 | 21.3 | 16 | 38 | 32 | 2 |
insert! | 20 | 105 | 75 | 14 | 4 | M12 | 26.9 | 18 | 40 | 40 | 2.3 |
insert! | 25 | 115 | 85 | 14 | 4 | M12 | 33.7 | 18 | 40 | 46 | 2.6 |
insert! | 32 | 140 | 100 | 18 | 4 | M16 | 42.4 | 18 | 42 | 56 | 2.6 |
insert! | 40 | 150 | 110 | 18 | 4 | M16 | 48.3 | 18 | 45 | 64 | 2.6 |
insert! | 50 | 165 | 125 | 18 | 4 | M16 | 60.3 | 18 | 45 | 74 | 2.9 |
insert! | 65 | 185 | 145 | 18 | 8 | M16 | 76.1 | 18 | 45 | 92 | 2.9 |
insert! | 80 | 200 | 160 | 18 | 8 | M16 | 88.9 | 20 | 50 | 105 | 3.2 |
insert! | 100 | 220 | 180 | 18 | 8 | M16 | 114.3 | 20 | 52 | 131 | 3.6 |
insert! | 125 | 250 | 210 | 18 | 8 | M16 | 139.7 | 22 | 55 | 156 | 4 |
insert! | 150 | 285 | 240 | 22 | 8 | M20 | 168.3 | 22 | 55 | 184 | 4.5 |
insert! | 200 | 340 | 295 | 22 | 8 | M20 | 219.1 | 24 | 62 | 234 | 6.3 |
insert! | 250 | 395 | 350 | 22 | 12 | M20 | 273.0 | 26 | 68 | 292 | 6.3 |
insert! | 300 | 445 | 400 | 22 | 12 | M20 | 323.9 | 26 | 68 | 342 | 7.1 |
insert! | 350 | 505 | 460 | 22 | 16 | M20 | 355.6 | 26 | 68 | 385 | 7.1 |
insert! | 400 | 565 | 515 | 26 | 16 | M24 | 406.4 | 26 | 72 | 440 | 7.1 |
insert! | 450 | 615 | 565 | 26 | 20 | M24 | 457 | 28 | 72 | 488 | 7.1 |
insert! | 500 | 670 | 620 | 26 | 20 | M24 | 508 | 28 | 75 | 542 | 7.1 |
insert! | 600 | 780 | 725 | 30 | 20 | M27 | 610 | 30 | 82 | 642 | 7.1 |
insert! | 700 | 895 | 840 | 30 | 24 | M27 | 711 | 35 | 85 | 746 | 8.0 |
insert! | 800 | 1015 | 950 | 33 | 24 | M30 | 813 | 38 | 96 | 850 | 8.8 |
insert! | 900 | 1115 | 1050 | 33 | 28 | M30 | 914 | 38 | 99 | 950 | 12.5 |
insert! | 1000 | 1230 | 1160 | 36 | 28 | M33 | 1016 | 44 | 105 | 1052 | 12.5 |
insert! | 1200 | 1455 | 1380 | 39 | 32 | M36 | 1219 | 55 | 132 | 1256 | 12.5 |
insert! | 1400 | 1675 | 1590 | 42 | 36 | M39 | 1422 | 65 | 143 | 1460 | 14.2 |
insert! | 1600 | 1915 | 1820 | 48 | 40 | M45 | 1626 | 75 | 159 | 1666 | 16.0 |
insert! | 1800 | 2155 | 2020 | 48 | 44 | M45 | 1829 | 85 | 175 | 1868 | 17.5 |
insert! | 2000 | 2325 | 2230 | 48 | 48 | M45 | 2032 | 90 | 186 | 2072 | 17.5 |
insert! | 2200 | 2550 | 2440 | 56 | 52 | M52 | 2235 | 100 | 202 | 2275 | 20 |
insert! | 2400 | 2760 | 2650 | 56 | 56 | M52 | 2438 | 110 | 218 | 2475 | 22.2 |
insert! | 2600 | 2960 | 2850 | 56 | 60 | M52 | 2620 | 110 | 224 | 2680 | 25 |
insert! | 2800 | 3180 | 3075 | 56 | 64 | M52 | 2820 | 124 | 244 | 2882 | 25 |
insert! | 3000 | 3405 | 3290 | 62 | 68 | M56 | 3020 | 132 | 257 | 3085 | 32 |
custom! |
undo! redo!
change color!
make!
startpoint
endpoint insert!
It's FREE and FUN!
and more.
3 18
