Dimensions, sizes and specifications of EN 1092-1 Type 11 Welding Neck Flanges PN6/6BAR
NB! If there is problem with inserting flanges - try to reinstall the extension by using alternative 3 as described in the right column.
Nominal Size - DN | Outside Diameter of Flange - D | Diameter of Bolt Circle - K | Diameter of Bolt Hole - L | Bolting Number | Bolting Size | Outside Diameter of Neck - A | Flange Thickness - C2 | Length - H2 | Neck Diameters - N1 | Wall Thickness - S | |
mm | mm | mm | mm | mm | mm | mm | mm | mm | |||
insert! | 10 | 75 | 50 | 11 | 4 | M10 | 17.2 | 12 | 28 | 26 | 2 |
insert! | 15 | 80 | 55 | 11 | 4 | M10 | 21.3 | 12 | 30 | 30 | 2 |
insert! | 20 | 90 | 65 | 11 | 4 | M10 | 26.9 | 14 | 32 | 38 | 2.3 |
insert! | 25 | 100 | 75 | 11 | 4 | M10 | 33.7 | 14 | 35 | 42 | 2.6 |
insert! | 32 | 120 | 90 | 14 | 4 | M12 | 42.4 | 14 | 35 | 55 | 2.6 |
insert! | 40 | 130 | 100 | 14 | 4 | M12 | 48.3 | 14 | 38 | 62 | 2.6 |
insert! | 50 | 140 | 110 | 14 | 4 | M12 | 60.3 | 14 | 38 | 74 | 2.9 |
insert! | 65 | 160 | 130 | 14 | 4 | M12 | 76.1 | 14 | 38 | 88 | 2.9 |
insert! | 80 | 190 | 150 | 18 | 4 | M16 | 88.9 | 16 | 42 | 102 | 3.2 |
insert! | 100 | 210 | 170 | 18 | 4 | M16 | 114.3 | 16 | 45 | 130 | 3.6 |
insert! | 125 | 240 | 200 | 18 | 8 | M16 | 139.7 | 18 | 48 | 155 | 4 |
insert! | 150 | 265 | 225 | 18 | 8 | M16 | 168.3 | 18 | 48 | 184 | 4.5 |
insert! | 200 | 320 | 280 | 18 | 8 | M16 | 219.1 | 20 | 55 | 236 | 6.3 |
insert! | 250 | 375 | 335 | 18 | 12 | M16 | 273.0 | 22 | 60 | 290 | 6.3 |
insert! | 300 | 440 | 395 | 22 | 12 | M20 | 323.9 | 22 | 62 | 342 | 7.1 |
insert! | 350 | 490 | 445 | 22 | 12 | M20 | 355.6 | 22 | 62 | 385 | 7.1 |
insert! | 400 | 540 | 495 | 22 | 16 | M20 | 406.4 | 22 | 65 | 438 | 7.1 |
insert! | 450 | 595 | 550 | 22 | 16 | M20 | 457 | 22 | 65 | 492 | 7.1 |
insert! | 500 | 645 | 600 | 22 | 20 | M20 | 508 | 24 | 68 | 538 | 7.1 |
insert! | 600 | 755 | 705 | 26 | 20 | M24 | 610 | 30 | 70 | 640 | 7.1 |
insert! | 700 | 860 | 810 | 26 | 24 | M24 | 711 | 30 | 76 | 740 | 7.1 |
insert! | 800 | 975 | 920 | 30 | 24 | M27 | 813 | 30 | 76 | 842 | 7.1 |
insert! | 900 | 1075 | 1020 | 30 | 24 | M27 | 914 | 34 | 78 | 942 | 7.1 |
insert! | 1000 | 1175 | 1120 | 30 | 28 | M27 | 1016 | 38 | 82 | 1045 | 7.1 |
insert! | 1200 | 1405 | 1340 | 33 | 32 | M30 | 1219 | 42 | 104 | 1248 | 7.1 |
insert! | 1400 | 1630 | 1560 | 36 | 36 | M33 | 1422 | 56 | 114 | 1452 | 7.1 |
insert! | 1600 | 1830 | 1760 | 36 | 40 | M33 | 1626 | 63 | 119 | 1655 | 8 |
insert! | 1800 | 2045 | 1970 | 39 | 44 | M36 | 1829 | 69 | 133 | 1855 | 10 |
insert! | 2000 | 2265 | 2180 | 42 | 48 | M39 | 2032 | 74 | 146 | 2058 | 10 |
insert! | 2200 | 2475 | 2390 | 42 | 52 | M39 | 2235 | 81 | 154 | 2268 | 10 |
insert! | 2400 | 2685 | 2600 | 42 | 56 | M39 | 2438 | 87 | 168 | 2462 | 10 |
insert! | 2600 | 2905 | 2810 | 48 | 60 | M45 | 2620 | 91 | 175 | 2665 | 10 |
insert! | 2800 | 3115 | 3020 | 48 | 64 | M45 | 2820 | 101 | 188 | 2865 | 10 |
insert! | 3000 | 3315 | 3220 | 48 | 68 | M45 | 3020 | 102 | 192 | 3068 | 10 |
insert! | 3200 | 3525 | 3430 | 48 | 72 | M45 | 3220 | 106 | 202 | 3272 | 10 |
insert! | 3400 | 3735 | 3640 | 48 | 76 | M45 | 3420 | 110 | 214 | 3475 | 10 |
insert! | 3600 | 3970 | 3860 | 56 | 80 | M52 | 3620 | 124 | 229 | 3678 | 10 |
custom! |
Tip! - use the "Rotate Object" bellow to turn the object after it is inserted.
undo! redo!
change color!
make!
startpoint
endpoint insert!
It's FREE and FUN!
and more.
3 18
