Wide-flange and I-flange beams and columns
Aluminum Association Standard I-Beams -
Dimensions and Static parameters of Aluminum I-beams - Imperial Units
BS 4 - Joists with Taper Flanges -
BS 4 part 1: 1993 Joist sections with Taper Flanges
H - Japanese Sections -
Japanese H sections according JIS G 3192:2005
HE-A - European Steel Beams -
HEA steel beams according DIN 1025 and Euronorm 53-62
HE-AA - European Steel Beams -
HEAA steel beams according DIN 1025 and Euronorm 53-62
HE-B - European Steel Beams -
HEB steel beams according DIN 1025 and Euronorm 53-62
HE-M - European Steel Beams -
HEM steel beams according DIN 1025 and Euronorm 53-62
HP - American Wide Flange Bearing Piles -
Properties of American wide flange bearing piles - Metric Units
IPE - European I Beams -
IPE medium flange I-Beams according Euronorm 19-57
IPE-A - European I Beams -
IPE A medium flange I-Beams according Euronorm 19-57
IPE-O - European I Beams -
IPE O medium flange I-Beams according Euronorm 19-57
IPN - European I Beams -
European I Beams - IPN, dimensions and properties
S - American Standard I-Beams -
ASTM A6 - Dimensions and static properties of American Standard Section Beams - Imperial Units
UB - British Universal Beams -
BSI BS 4-1 - Properties of British Universal Beams - Metric Units
UBP - British Universal Bearing Piles with Wide Flanges -
Properties of British Universal bearing piles with wide flanges - Metric Units
UC - British Universal Columns -
Properties of BSI BS 4-1 British Universal Columns - Metric Units
W - American Standard Steel Wide Flange Beams -
ASTM A6 - Dimensions and static parameters of American steel wide flange beams - Imperial Units
Edit:
undo -
redo
Color:
change color!
View:
iso -
top -
front -
right -
left -
back -
bottom
Make Component:
Rotate Object(s):
degrees around
red,
green or
blue
move/copy!
no. copies
red
green
blue
with multiple copies.
move!
New! Change Insertion Point
red
green
blue
- Start position
red
green
blue
- End position
insert!
insert!
red (size)
green (size)
blue (vertical position)
insert!
red (horizontal position)
green (size)
blue (vertical size)
insert!
red (size)
green (horizontal position)
Insert Box: - add a box
insert!
red (width)
green (depth)
blue (height)
insert!
name
url
9 11 21
It's FREE and
it's FUN!
Download
engineeringtoolbox.rb
Exit and reload SketchUp!
or
(Mac)
(Mac users look here!)
add components to the
groups!
on Mac computers.
