Home
Structural and Bar Sections
Flange Beams and Columns
Structural steel beams used for deep foundation applications to add stiffness and support to sheet pile walls and foundations
Designation |
Depth in |
Width in |
Thickness Web in |
Thickness Flange in |
Sectional Area in**2 |
Weight lb/ft |
Moment of Inertia - Ix in**4 |
Moment of Inertia - Iy in**4 |
Section of Modulus - Sx in**3 |
Section of Modulus - Sy in**3 |
insert! | HP 8 x 36 | 8.02 | 8.16 | 0.445 | 0.445 | 10.6 | 36 | ||||
insert! | HP 10 x 42 | 9.70 | 10.10 | 0.415 | 0.420 | 12.4 | 42 | ||||
insert! | HP 10 x 57 | 9.99 | 10.20 | 0.565 | 0.565 | 16.7 | 57 | ||||
insert! | HP 12 x 53 | 11.80 | 12.00 | 0.435 | 0.435 | 15.5 | 53 | ||||
insert! | HP 12 x 63 | 11.90 | 12.10 | 0.515 | 0.515 | 18.4 | 63 | ||||
insert! | HP 12 x 74 | 12.10 | 12.20 | 0.605 | 0.610 | 21.8 | 74 | ||||
insert! | HP 12 x 84 | 12.30 | 12.30 | 0.685 | 0.685 | 24.6 | 84 | ||||
insert! | HP 12 x 89 | 12.36 | 12.32 | 0.720 | 0.720 | 25.9 | 89 | ||||
insert! | HP 12 x 102 | 12.56 | 12.64 | 0.819 | 0.819 | 29.6 | 102 | ||||
insert! | HP 12 x 117 | 12.76 | 12.87 | 0.929 | 0.929 | 34.4 | 117 | ||||
insert! | HP 14 x 73 | 13.60 | 14.60 | 0.505 | 0.505 | 21.4 | 73 | ||||
insert! | HP 14 x 89 | 13.80 | 14.70 | 0.615 | 0.615 | 26.1 | 89 | ||||
insert! | HP 14 x 102 | 14.00 | 14.80 | 0.705 | 0.705 | 30.1 | 102 | ||||
insert! | HP 14 x 117 | 14.20 | 14.90 | 0.805 | 0.805 | 34.4 | 117 | ||||
insert! | HP 16 x 88 | 15.30 | 15.70 | 0.540 | 0.540 | 25.8 | 88 | ||||
insert! | HP 16 x 101 | 15.50 | 15.80 | 0.625 | 0.625 | 29.9 | 101 | ||||
insert! | HP 16 x 121 | 15.80 | 15.90 | 0.750 | 0.750 | 35.8 | 121 | ||||
insert! | HP 16 x 141 | 16.00 | 16.00 | 0.875 | 0.875 | 41.7 | 141 | ||||
insert! | HP 16 x 162 | 16.30 | 16.10 | 1.000 | 1.000 | 47.7 | 162 | ||||
insert! | HP 16 x 183 | 16.50 | 16.30 | 1.130 | 1.130 | 51.1 | 183 | ||||
insert! | HP 18 x 135 | 17.50 | 17.80 | 0.750 | 0.750 | 39.9 | 135 | ||||
insert! | HP 18 x 157 | 17.70 | 17.90 | 0.870 | 0.870 | 46.2 | 157 | ||||
insert! | HP 18 x 181 | 18.00 | 18.00 | 1.000 | 1.000 | 53.2 | 181 | ||||
insert! | HP 18 x 204 | 18.30 | 18.10 | 1.130 | 1.130 | 60.2 | 204 | ||||
custom! |
undo! redo!
change color!
make!
startpoint
endpoint insert!
It's FREE and FUN!
If you experience problems with the functionality - first try to reload the cached page with the link in the top left corner - then try installation with alternative 2 or 3.
and more.
5 3
