Components for steel and aluminum structures - flange beams, hollow sections and more
Angles -
Construction angles with equal and unequal legs - L shaped cross-sections.
Channels -
Construction channels - dimensions and static parameters..
Circular Hollow Sections -
Circular hollow sections
Flange Beams and Columns -
Wide-flange and I-flange beams and columns
Flat Sections -
Flat structural sections
Hollow Structural Sections -
HSS - Hollow Structural Sections - square and rectangular sections.
Tee Sections -
Tee sections
Edit:
undo -
redo
Color:
change color!
View:
iso -
top -
front -
right -
left -
back -
bottom
Make Component:
Rotate Object(s):
degrees around
red,
green or
blue
move/copy!
no. copies
red
green
blue
with multiple copies.
move!
New! Change Insertion Point
red
green
blue
- Start position
red
green
blue
- End position
insert!
insert!
red (size)
green (size)
blue (vertical position)
insert!
red (horizontal position)
green (size)
blue (vertical size)
insert!
red (size)
green (horizontal position)
Insert Box: - add a box
insert!
red (width)
green (depth)
blue (height)
insert!
name
url
9 11 21
It's FREE and
it's FUN!
Download
engineeringtoolbox.rb
Exit and reload SketchUp!
or
(Mac)
(Mac users look here!)
add components to the
groups!
on Mac computers.
