Sign in!
Home > Structural Sections > Angles >
Construction angles with equal and unequal legs - L shaped cross-sections.
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
12 2 7
