Sign in!
Home > Structural Sections > Angles >
L Steel Angles with Unequal Legs
Dimensions and static parameters of steel angles with imperial units
l steel angle unequal leg
DesignationDepthWidthThicknessSectional AreaWeightMoment of Inertia - ISection of Modulus - Wx
inininin'*2lb/ftin**4in**3
insert!9 x 4 x 5/8940.6257.7326.364.911.5
insert!9 x 4 x 9/16940.563723.859.110.4
insert!9 x 4 x 1/2940.5006.2521.353.29.34
insert!8 x 6 x 1861.0001344.280.815.1
insert!8 x 6 x 7/8860.87511.539.172.313.4
insert!8 x 6 x 3/4860.7509.9433.863.411.7
insert!8 x 6 x 5/8860.6258.3628.554.19.87
insert!8 x 6 x 9/16860.5637.5625.7649.38.95
insert!8 x 6 x 1/2860.5006.752344.38.02
insert!8 x 6 x 7/16860.4385.9320.239.27.1
insert!8 x 4 x 1841.0001137.469.614.1
insert!8 x 4 x 3/4840.7508.4428.754.910.9
insert!8 x 4 x 9/16840.5636.4321.942.88.35
insert!8 x 4 x 1/2840.5005.7519.638.57.49
insert!7 x 4 x 3/4740.7507.6926.237.88.42
insert!7 x 4 x 5/8740.6256.4822.132.47.14
insert!7 x 4 x 1/2740.5005.2517.926.75.81
insert!7 x 4 x 3/8740.3753.9813.620.64.44
insert!6 x 4 x 7/8640.8757.9827.227.77.15
insert!6 x 4 x 3/4640.7506.9423.624.56.25
insert!6 x 4 x 5/8640.6255.862021.15.31
insert!6 x 4 x 9/16640.5635.3118.119.34.83
insert!6 x 4 x 1/2640.5004.7516.217.44.33
insert!6 x 4 x 7/16640.3684.1814.315.53.83
insert!6 x 4 x 3/8640.3753.6112.313.53.32
insert!6 x 4 x 5/16640.3133.0310.311.42.79
insert!6 x 3 1/2 x 1/263.50.5004.515.316.64.24
insert!6 x 3 1/2 x 3/863.50.3753.4211.712.93.24
insert!6 x 3 1/2 x 5/1663.50.3132.879.810.92.73
insert!5 x 3 1/2 x 3/453.50.7505.8119.813.94.28
insert!5 x 3 1/2 x 5/853.50.6254.9216.8123.65
insert!5 x 3 1/2 x 1/253.50.500413.6102.99
insert!5 x 3 1/2 x 7/1653.50.4383.53128.92.64
insert!5 x 3 1/2 x 3/853.50.3753.0510.47.782.29
insert!5 x 3 1/2 x 5/1653.50.3132.568.76.61.94
insert!5 x 3 1/2 x 1/453.50.2502.0675.391.57
insert!5 x 3 x 5/8530.6254.6115.711.43.55
insert!5 x 3 x 1/2530.5003.7512.89.452.91
insert!5 x 3 x 7/16530.4383.3111.38.432.58
insert!5 x 3 x 3/8530.3752.869.87.372.24
insert!5 x 3 x 5/16530.3132.48.26.261.89
insert!5 x 3 x 1/4530.2501.946.65.111.53
insert!4 x 3 1/2 x 5/8430.6254.314.76.372.35
insert!4 x 3 1/2 x 1/2430.5003.511.95.321.94
insert!4 x 3 1/2 x 7/16430.4383.0910.64.761.72
insert!4 x 3 1/2 x 3/8430.3752.679.14.181.49
insert!4 x 3 1/2 x 5/16430.3132.257.73.561.26
insert!4 x 3 1/2 x 1/4430.2501.816.22.911.03
insert!4 x 3 x 5/8430.6253.9813.66.032.3
insert!4 x 3 x 1/2430.5003.2511.15.051.89
insert!4 x 3 x 7/16430.4382.879.84.521.68
insert!4 x 3 x 3/8430.3752.488.53.961.46
insert!4 x 3 x 5/16430.3132.097.23.381.23
insert!4 x 3 x 1/4430.2501.695.82.771
insert!3 1/2 x 3 x 1/23.530.500310.23.451.45
insert!3 1/2 x 3 x 7/163.530.4382.659.13.11.29
insert!3 1/2 x 3 x 3/83.530.3752.37.92.721.13
insert!3 1/2 x 3 x 5/163.530.3131.936.62.330.95
insert!3 1/2 x 3 x 1/43.530.2501.565.41.910.78
insert!3 1/2 x 2 1/2 x 1/23.52.50.5002.759.43.241.41
insert!3 1/2 x 2 1/2 x 7/163.52.50.4382.438.32.911.26
insert!3 1/2 x 2 1/2 x 3/83.52.50.3752.117.22.561.09
insert!3 1/2 x 2 1/2 x 5/163.52.50.3131.786.12.190.93
insert!3 1/2 x 2 1/2 x 1/43.52.50.2501.444.91.80.76
insert!3 x 2 1/2 x 1/232.50.5002.58.52.081.04
insert!3 x 2 1/2 x 7/1632.50.4382.217.61.880.93
insert!3 x 2 1/2 x 3/832.50.3751.926.61.660.81
insert!3 x 2 1/2 x 5/1632.50.3131.625.61.420.69
insert!3 x 2 1/2 x 1/432.50.2501.314.51.170.56
insert!3 x 2 1/2 x 3/1632.50.18813.390.910.43
insert!3 x 2 x 1/2320.5002.257.71.921
insert!3 x 2 x 7/16320.43826.81.730.89
insert!3 x 2 x 3/8320.3751.735.91.530.78
insert!3 x 2 x 5/16320.3131.4651.320.66
insert!3 x 2 x 1/4320.2501.194.11.090.54
insert!3 x 2 x 3/16320.1880.93.10.840.42
insert!2 1/2 x 2 x 3/82.520.3751.555.30.910.55
insert!2 1/2 x 2 x 5/162.520.3131.314.50.790.47
insert!2 1/2 x 2 x 1/42.520.2501.063.620.650.38
insert!2 1/2 x 2 x 3/162.520.1880.812.750.510.29
custom!
Edit:
undo - redo
Color:
View:
Make Component:
Rotate Object(s):
New! Change Insertion Point
red green blue - End position
insert!
Insert Box: - add a box
insert! name url
12 2 9
