EN 10056-1: 1998 Dimensions and static parameters of steel angles metric units
| Designation | Depth | Width | Thickness | Root Radius | Sectional Area | Weight | Moment of Inertia - I | |
| mm | mm | mm | mm | cm**2 | kg/m | cm**4 | ||
| insert! | RSA 250 x 250 x 35 | 250 | 250 | 35 | 18 | 163 | 128 | 9264 |
| insert! | RSA 250 x 250 x 32 | 250 | 250 | 32 | 20 | 150 | 118 | 8597 |
| insert! | RSA 250 x 250 x 28 | 250 | 250 | 28 | 18 | 133 | 104 | 7697 |
| insert! | RSA 250 x 250 x 25 | 250 | 250 | 25 | 20 | 119 | 93.6 | 6975 |
| insert! | RSA 200 x 200 x 24 | 200 | 200 | 24 | 18 | 90.6 | 71.1 | 3331 |
| insert! | RSA 200 x 200 x 20 | 200 | 200 | 20 | 18 | 76.3 | 59.9 | 2851 |
| insert! | RSA 200 x 200 x 18 | 200 | 200 | 18 | 18 | 69.1 | 54.2 | 2600 |
| insert! | RSA 200 x 200 x 16 | 200 | 200 | 16 | 18 | 61.8 | 48.5 | 2341 |
| insert! | RSA 180 x 180 x 18 | 180 | 180 | 18 | 18 | 61.9 | 48.6 | 1866 |
| insert! | RSA 180 x 180 x 16 | 180 | 180 | 16 | 18 | 55.4 | 43.5 | 1682 |
| insert! | RSA 160 x 160 x 15 | 160 | 160 | 15 | 17 | 46.1 | 36.2 | 1099 |
| insert! | RSA 150 x 150 x 18 | 150 | 150 | 18 | 16 | 51 | 40.1 | 1050 |
| insert! | RSA 150 x 150 x 15 | 150 | 150 | 15 | 16 | 43 | 33.8 | 898 |
| insert! | RSA 150 x 150 x 12 | 150 | 150 | 12 | 16 | 34.8 | 27.3 | 737 |
| insert! | RSA 150 x 150 x 10 | 150 | 150 | 10 | 16 | 29.3 | 23 | 624 |
| insert! | RSA 130 x 130 x 12 | 130 | 130 | 12 | 14 | 30 | 23.5 | 472 |
| insert! | RSA 120 x 120 x 15 | 120 | 120 | 15 | 13 | 33.9 | 26.6 | 445 |
| insert! | RSA 120 x 120 x 12 | 120 | 120 | 12 | 13 | 27.5 | 21.6 | 368 |
| insert! | RSA 120 x 120 x 10 | 120 | 120 | 10 | 13 | 23.2 | 18.2 | 313 |
| insert! | RSA 120 x 120 x 8 | 120 | 120 | 8 | 13 | 18.7 | 14.7 | 255 |
| insert! | RSA 100 x 100 x 15 | 100 | 100 | 15 | 12 | 27.9 | 21.9 | 249 |
| insert! | RSA 100 x 100 x 12 | 100 | 100 | 12 | 12 | 22.7 | 17.8 | 207 |
| insert! | RSA 100 x 100 x 10 | 100 | 100 | 10 | 12 | 19.2 | 15.0 | 177 |
| insert! | RSA 100 x 100 x 8 | 100 | 100 | 8 | 12 | 15.5 | 12.2 | 145 |
| insert! | RSA 90 x 90 x 12 | 90 | 90 | 12 | 11 | 20.3 | 15.9 | 148 |
| insert! | RSA 90 x 90 x 10 | 90 | 90 | 10 | 11 | 17.1 | 13.4 | 127 |
| insert! | RSA 90 x 90 x 9 | 90 | 90 | 9 | 11 | 15.5 | 12.2 | 116 |
| insert! | RSA 90 x 90 x 8 | 90 | 90 | 8 | 11 | 13.9 | 10.9 | 104 |
| insert! | RSA 90 x 90 x 7 | 90 | 90 | 7 | 11 | 12.2 | 9.6 | 92.5 |
| insert! | RSA 90 x 90 x 6 | 90 | 90 | 6 | 11 | 10.6 | 8.3 | 80.3 |
| insert! | RSA 80 x 80 x 10 | 80 | 80 | 10 | 10 | 15.1 | 11.9 | 87.5 |
| insert! | RSA 80 x 80 x 8 | 80 | 80 | 8 | 10 | 12.3 | 9.6 | 72.2 |
| insert! | RSA 80 x 80 x 6 | 80 | 80 | 6 | 10 | 9.4 | 7.3 | 55.8 |
| insert! | RSA 75 x 75 x 8 | 75 | 75 | 8 | 9 | 11.4 | 9.0 | 59.1 |
| insert! | RSA 75 x 75 x 6 | 75 | 75 | 6 | 9 | 8.7 | 6.9 | 45.8 |
| insert! | RSA 70 x 70 x 10 | 70 | 70 | 10 | 9 | 13.7 | 10.3 | 57.2 |
| insert! | RSA 70 x 70 x 7 | 70 | 70 | 8 | 9 | 10.6 | 8.4 | 47.5 |
| insert! | RSA 70 x 70 x 8 | 70 | 70 | 7 | 9 | 9.4 | 7.4 | 42.3 |
| insert! | RSA 70 x 70 x 6 | 70 | 70 | 6 | 9 | 8.1 | 6.4 | 36.9 |
| insert! | RSA 65 x 65 x 7 | 65 | 65 | 7 | 9 | 8.7 | 6.8 | 33.4 |
| insert! | RSA 60 x 60 x 10 | 60 | 60 | 10 | 8 | 11.1 | 8.7 | 34.9 |
| insert! | RSA 60 x 60 x 8 | 60 | 60 | 8 | 8 | 9.1 | 7.1 | 29.2 |
| insert! | RSA 60 x 60 x 6 | 60 | 60 | 6 | 8 | 6.9 | 5.4 | 22.8 |
| insert! | RSA 60 x 60 x 5 | 60 | 60 | 5 | 8 | 5.8 | 4.6 | 19.4 |
| insert! | RSA 50 x 50 x 8 | 50 | 50 | 8 | 7 | 7.4 | 5.8 | 16.3 |
| insert! | RSA 50 x 50 x 6 | 50 | 50 | 6 | 7 | 5.7 | 4.5 | 12.8 |
| insert! | RSA 50 x 50 x 5 | 50 | 50 | 5 | 7 | 4.8 | 3.8 | 11.0 |
| insert! | RSA 50 x 50 x 4 | 50 | 50 | 4 | 7 | 3.9 | 3.1 | 9.0 |
| insert! | RSA 50 x 50 x 3 | 50 | 50 | 3 | 7 | 3.0 | 2.3 | 6.9 |
| insert! | RSA 45 x 45 x 6 | 45 | 45 | 6 | 7 | 5.1 | 4.0 | 9.2 |
| insert! | RSA 45 x 45 x 5 | 45 | 45 | 5 | 7 | 4.3 | 3.4 | 7.8 |
| insert! | RSA 45 x 45 x 4.5 | 45 | 45 | 4.5 | 7 | 3.9 | 3.1 | 7.2 |
| insert! | RSA 45 x 45 x 4 | 45 | 45 | 4 | 7 | 3.5 | 2.7 | 6.4 |
| insert! | RSA 45 x 45 x 3 | 45 | 45 | 3 | 7 | 2.7 | 2.1 | 4.9 |
| insert! | RSA 40 x 40 x 6 | 40 | 40 | 6 | 6 | 4.5 | 3.5 | 6.3 |
| insert! | RSA 40 x 40 x 5 | 40 | 40 | 5 | 6 | 3.8 | 3.0 | 5.4 |
| insert! | RSA 40 x 40 x 4 | 40 | 40 | 4 | 6 | 3.1 | 2.4 | 4.5 |
| insert! | RSA 40 x 40 x 3 | 40 | 40 | 3 | 6 | 2.4 | 1.8 | 3.5 |
| insert! | RSA 35 x 35 x 4 | 35 | 35 | 4 | 5 | 2.7 | 2.1 | 3.0 |
| insert! | RSA 30 x 30 x 5 | 30 | 30 | 5 | 5 | 2.8 | 2.2 | 2.2 |
| insert! | RSA 30 x 30 x 4 | 30 | 30 | 4 | 5 | 2.3 | 1.8 | 1.8 |
| insert! | RSA 30 x 30 x 3 | 30 | 30 | 3 | 5 | 1.7 | 1.4 | 1.4 |
| insert! | RSA 25 x 25 x 5 | 25 | 25 | 5 | 3.5 | 2.3 | 1.8 | 1.2 |
| insert! | RSA 25 x 25 x 4 | 25 | 25 | 4 | 3.5 | 1.9 | 1.5 | 1.0 |
| insert! | RSA 25 x 25 x 3 | 25 | 25 | 3 | 3.5 | 1.4 | 1.1 | 0.80 |
| insert! | RSA 20 x 20 x 3 | 20 | 20 | 3 | 3.5 | 1.1 | 0.9 | 0.39 |
| custom! | ||||||||
Edit:
undo -
redo
Color:
change color!
View:
iso -
top -
front -
right -
left -
back -
bottom
Make Component:
Rotate Object(s):
degrees around
red,
green or
blue
move/copy!
no. copies
red
green
blue
with multiple copies.
move!
New! Change Insertion Point
red
green
blue
- Start position
red
green
blue
- End position
insert!
insert!
red (size)
green (size)
blue (vertical position)
insert!
red (horizontal position)
green (size)
blue (vertical size)
insert!
red (size)
green (horizontal position)
Insert Box: - add a box
insert!
red (width)
green (depth)
blue (height)
insert!
name
url
9 11 22
It's FREE and
it's FUN!
Download
engineeringtoolbox.rb
Exit and reload SketchUp!
or
(Mac)
(Mac users look here!)
add components to the
groups!
on Mac computers.
