Home
Structural and Bar Sections
Angles
ASTM A6/A6M Dimensions and static parameters of steel angles with imperial units
ASTM Designation: A6/A6M - 12, Standard Specification for General Requirements for Rolled Structural Steel Bars, Plates, Shapes, and Sheet Piling - "L" Shapes (Equal Legs)
A shape is classed a "Bar Size Shape" when its greatest dimension is less than 3 inches. It is a "Structural Shape" when at least one of its dimensions is 3 inches or greater.
Designation |
Depth in |
Width in |
Thickness in |
Sectional Area in**2 |
Weight lb/ft |
Moment of Inertia - I in**4 |
| insert! | L12 x 12 x 1 3/8 | 12 | 12 | 1.375 | 30.9 | 105 | 410.0 |
| insert! | L12 x 12 x 1 1/4 | 12 | 12 | 1.250 | 28.3 | 96.4 | 377.5 |
| insert! | L12 x 12 x 1 1/8 | 12 | 12 | 1.125 | 25.6 | 87.2 | 344.1 |
| insert! | L12 x 12 x 1 | 12 | 12 | 1.0 | 22.9 | 77.8 | 310.4 |
| insert! | L10 x 10 x 1 3/8 | 10 | 10 | 1.375 | 25.6 | 87.1 | 232.1 |
| insert! | L10 x 10 x 1 1/4 | 10 | 10 | 1.250 | 23.5 | 79.9 | 215.1 |
| insert! | L10 x 10 x 1 1/8 | 10 | 10 | 1.125 | 21.2 | 72.3 | 196.2 |
| insert! | L10 x 10 x 1 | 10 | 10 | 1.0 | 19.0 | 64.7 | 177.3 |
| insert! | L10 x 10 x 7/8 | 10 | 10 | 0.875 | 16.7 | 56.9 | 157.6 |
| insert! | L10 x 10 x 3/4 | 10 | 10 | 0.750 | 14.4 | 49.1 | 137 |
| insert! | L8 x 8 x 1 1/8 | 8 | 8 | 1.125 | 16.7 | 56.9 | 98 |
| insert! | L8 x 8 x 1 | 8 | 8 | 1 | 15 | 51 | 89 |
| insert! | L8 x 8 x 7/8 | 8 | 8 | 0.875 | 13.2 | 45 | 79.6 |
| insert! | L8 x 8 x 3/4 | 8 | 8 | 0.75 | 11.4 | 38.9 | 69.7 |
| insert! | L8 x 8 x 5/8 | 8 | 8 | 0.625 | 9.61 | 32.7 | 59.4 |
| insert! | L8 x 8 x 9/16 | 8 | 8 | 0.5625 | 8.68 | 29.6 | 54.1 |
| insert! | L8 x 8 x 1/2 | 8 | 8 | 0.5 | 7.75 | 26.4 | 48.6 |
| insert! | L6 x 6 x 1 | 6 | 6 | 1 | 11 | 37.4 | 35.5 |
| insert! | L6 x 6 x 7/8 | 6 | 6 | 0.875 | 9.73 | 33.1 | 31.9 |
| insert! | L6 x 6 x 3/4 | 6 | 6 | 0.75 | 8.44 | 28.7 | 28.2 |
| insert! | L6 x 6 x 5/8 | 6 | 6 | 0.625 | 7.11 | 24.2 | 24.2 |
| insert! | L6 x 6 x 9/16 | 6 | 6 | 0.5625 | 6.43 | 21.9 | 22.1 |
| insert! | L6 x 6 x 1/2 | 6 | 6 | 0.5 | 5.75 | 19.6 | 19.9 |
| insert! | L6 x 6 x 7/16 | 6 | 6 | 0.4375 | 5.06 | 17.2 | 17.7 |
| insert! | L6 x 6 x 3/8 | 6 | 6 | 0.375 | 4.36 | 14.9 | 15.4 |
| insert! | L6 x 6 x 5/16 | 6 | 6 | 0.3125 | 3.65 | 12.4 | 13 |
| insert! | L5 x 5 x 7/8 | 5 | 5 | 0.875 | 7.98 | 27.2 | 17.8 |
| insert! | L5 x 5 x 3/4 | 5 | 5 | 0.75 | 6.94 | 23.6 | 15.7 |
| insert! | L5 x 5 x 5/8 | 5 | 5 | 0.625 | 5.86 | 20 | 13.6 |
| insert! | L5 x 5 x 1/2 | 5 | 5 | 0.5 | 4.75 | 16.2 | 11.3 |
| insert! | L5 x 5 x 7/16 | 5 | 5 | 0.4375 | 4.18 | 14.3 | 10 |
| insert! | L5 x 5 x 3/8 | 5 | 5 | 0.375 | 3.61 | 12.3 | 8.74 |
| insert! | L5 x 5 x 5/16 | 5 | 5 | 0.3125 | 3.03 | 10.3 | 7.42 |
| insert! | L4 x 4 x 3/4 | 4 | 4 | 0.75 | 5.44 | 18.5 | 7.67 |
| insert! | L4 x 4 x 5/8 | 4 | 4 | 0.625 | 4.61 | 15.7 | 6.66 |
| insert! | L4 x 4 x 1/2 | 4 | 4 | 0.5 | 3.75 | 12.8 | 5.56 |
| insert! | L4 x 4 x 7/16 | 4 | 4 | 0.4375 | 3.31 | 11.3 | 4.97 |
| insert! | L4 x 4 x 3/8 | 4 | 4 | 0.375 | 2.86 | 9.8 | 4.36 |
| insert! | L4 x 4 x 5/16 | 4 | 4 | 0.3125 | 2.4 | 8.2 | 3.71 |
| insert! | L4 x 4 x 1/4 | 4 | 4 | 0.25 | 1.94 | 6.6 | 3.04 |
| insert! | L3 1/2 x 3 1/2 x 1/2 | 3.5 | 3.5 | 0.5 | 3.25 | 11.1 | 3.64 |
| insert! | L3 1/2 x 3 1/2 x 7/16 | 3.5 | 3.5 | 0.4375 | 2.87 | 9.8 | 3.26 |
| insert! | L3 1/2 x 3 1/2 x 3/8 | 3.5 | 3.5 | 0.375 | 2.48 | 8.5 | 2.87 |
| insert! | L3 1/2 x 3 1/2 x 5/16 | 3.5 | 3.5 | 0.3125 | 2.09 | 7.2 | 2.45 |
| insert! | L3 1/2 x 3 1/2 x 1/4 | 3.5 | 3.5 | 0.25 | 1.69 | 5.8 | 2.01 |
| insert! | L3 x 3 x 1/2 | 3 | 3 | 0.5 | 2.75 | 9.4 | 2.22 |
| insert! | L3 x 3 x 7/16 | 3 | 3 | 0.4375 | 2.43 | 8.3 | 1.99 |
| insert! | L3 x 3 x 3/8 | 3 | 3 | 0.375 | 2.11 | 7.2 | 1.76 |
| insert! | L3 x 3 x 5/16 | 3 | 3 | 0.3125 | 1.78 | 6.1 | 1.51 |
| insert! | L3 x 3 x 1/4 | 3 | 3 | 0.25 | 1.44 | 4.9 | 1.24 |
| insert! | L3 x 3 x 3/16 | 3 | 3 | 0.1875 | 1.09 | 3.71 | 0.962 |
| insert! | L2 1/2 x 2 1/2 x 1/2 | 2.5 | 2.5 | 0.5 | 2.25 | 7.7 | 1.23 |
| insert! | L2 1/2 x 2 1/2 x 3/8 | 2.5 | 2.5 | 0.375 | 1.73 | 5.9 | 0.984 |
| insert! | L2 1/2 x 2 1/2 x 5/16 | 2.5 | 2.5 | 0.3125 | 1.46 | 5 | 0.849 |
| insert! | L2 1/2 x 2 1/2 x 1/4 | 2.5 | 2.5 | 0.25 | 1.19 | 4.1 | 0.703 |
| insert! | L2 1/2 x 2 1/2 x 3/16 | 2.5 | 2.5 | 0.1875 | 0.902 | 3.1 | 0.547 |
| insert! | L2 x 2 x 1/2 | 2 | 2 | 0.5 | 5.92 | ||
| insert! | L2 x 2 x 3/8 | 2 | 2 | 0.375 | 1.36 | 4.7 | 0.479 |
| insert! | L2 x 2 x 5/16 | 2 | 2 | 0.3125 | 1.15 | 3.9 | 0.416 |
| insert! | L2 x 2 x 1/4 | 2 | 2 | 0.25 | 0.938 | 3.2 | 0.348 |
| insert! | L2 x 2 x 3/16 | 2 | 2 | 0.1875 | 0.715 | 2.4 | 0.272 |
| insert! | L2 x 2 x 1/8 | 2 | 2 | 0.125 | 0.484 | 1.7 | 0.19 |
| insert! | L1 3/4 x 1 3/4 x 1/4 | 1.750 | 1.750 | 0.250 | 0.813 | 2.77 | |
| insert! | L1 3/4 x 1 3/4 x 3/16 | 1.750 | 1.750 | 0.1875 | 0.621 | 2.12 | |
| insert! | L1 3/4 x 1 3/4 x 1/8 | 1.750 | 1.750 | 0.125 | 0.422 | 1.44 | |
| insert! | L1 1/2 x 1 1/2 x 3/8 | 1.5 | 1.5 | 0.375 | 3.35 | ||
| insert! | L1 1/2 x 1 1/2 x 5/16 | 1.5 | 1.5 | 0.3125 | 2.86 | ||
| insert! | L1 1/2 x 1 1/2 x 1/4 | 1.5 | 1.5 | 0.250 | 0.688 | 2.34 | |
| insert! | L1 1/2 x 1 1/2 x 3/16 | 1.5 | 1.5 | 0.1875 | 0.527 | 1.80 | |
| insert! | L1 1/2 x 1 1/2 x 5/32 | 1.5 | 1.5 | 0.15625 | 0.444 | 1.52 | |
| insert! | L1 1/2 x 1 1/2 x 1/8 | 1.5 | 1.5 | 0.125 | 0.359 | 1.23 | |
| insert! | L1 1/4 x 1 1/4 x 1/4 | 1.250 | 1.250 | 0.250 | 0.563 | 1.92 | |
| insert! | L1 1/4 x 1 1/4 x 3/16 | 1.250 | 1.250 | 0.1875 | 0.434 | 1.48 | |
| insert! | L1 1/4 x 1 1/4 x 1/8 | 1.250 | 1.250 | 0.125 | 0.297 | 1.01 | |
| insert! | L1 1/8 x 1 1/8 x 1/8 | 1.125 | 1.125 | 0.125 | 0.91 | ||
| insert! | L1 x 1 x 1/4 | 1.0 | 1.0 | 0.250 | 0.438 | 1.49 | |
| insert! | L1 x 1 x 3/16 | 1.0 | 1.0 | 0.1875 | 0.340 | 1.16 | |
| insert! | L1 x 1 x 1/8 | 1.0 | 1.0 | 0.125 | 0.234 | 0.80 | |
| insert! | L3/4 x 3/4 x 1/8 | 0.750 | 0.750 | 0.125 | 0.172 | 0.59 | |
| insert! | L7/8 x 7/8 x 1/8 | 0.875 | 0.875 | 0.125 | 0.7 | ||
| insert! | L5/8 x 5/8 x 1/8 | 0.625 | 0.625 | 0.125 | 0.48 | ||
| insert! | L1/2 x 1/2 x 1/8 | 0.5 | 0.5 | 0.125 | 0.38 | ||
| custom! |
undo! redo!
change color!
make!
startpoint
endpoint insert!
It's FREE and FUN!
If you experience problems with the functionality - first try to reload the cached page with the link in the top left corner - then try installation with alternative 2 or 3.
Note! The Engineering Toolbox extension in Sketchup Extension Warehouse only works for Sketchup editions up to 2023. For Sketchup edition 2024 and higher the extension can be installed by using installation alternative 2 or 3 below.
and more.
10 16
