EN 10056-1: 1998 Dimensions and static parameters of steel angles metric units
| Designation | Depth | Width | Thickness | Root Radius | Sectional Area | Weight | Moment of Inertia - Ix | Moment of Inertia - Iy | |
| mm | mm | mm | mm | cm**2 | kg/m | cm**4 | cm**4 | ||
| insert! | RSA 250 x 150 x 15 | 200 | 150 | 15 | 15 | 50.5 | 39.6 | 2022 | 979 |
| insert! | RSA 200 x 150 x 12 | 200 | 150 | 12 | 15 | 40.8 | 32.0 | 1652 | 803 |
| insert! | RSA 200 x 100 x 15 | 200 | 100 | 15 | 15 | 43 | 33.7 | 1758 | 299 |
| insert! | RSA 200 x 100 x 12 | 200 | 100 | 12 | 15 | 34.8 | 27.3 | 1440 | 247 |
| insert! | RSA 200 x 100 x 10 | 200 | 100 | 10 | 15 | 29.2 | 23.0 | 1219 | 210 |
| insert! | RSA 150 x 100 x 12 | 150 | 100 | 12 | 12 | 28.7 | 22.5 | 651 | 233 |
| insert! | RSA 150 x 100 x 10 | 150 | 100 | 10 | 12 | 24.2 | 19.0 | 553 | 198 |
| insert! | RSA 150 x 90 x 15 | 150 | 90 | 15 | 12 | 33.9 | 26.6 | 761 | 205 |
| insert! | RSA 150 x 90 x 12 | 150 | 90 | 12 | 12 | 27.5 | 21.6 | 627 | 171 |
| insert! | RSA 150 x 90 x 10 | 150 | 90 | 10 | 12 | 23.2 | 18.2 | 533 | 146 |
| insert! | RSA 150 x 75 x 15 | 150 | 75 | 15 | 11 | 31.6 | 24.8 | 713 | 120 |
| insert! | RSA 150 x 75 x 12 | 150 | 75 | 12 | 11 | 25.7 | 20.2 | 589 | 100 |
| insert! | RSA 150 x 75 x 10 | 150 | 75 | 10 | 11 | 21.6 | 17.0 | 501 | 86 |
| insert! | RSA 150 x 75 x 9 | 150 | 75 | 9 | 12 | 19.6 | 15.4 | 455 | 78 |
| insert! | RSA 135 x 65 x 10 | 135 | 65 | 10 | 11 | 19.1 | 15.0 | 356 | 55 |
| insert! | RSA 135 x 65 x 8 | 135 | 65 | 8 | 11 | 15.5 | 12.2 | 291 | 45 |
| insert! | RSA 125 x 75 x 12 | 125 | 75 | 12 | 11 | 22.7 | 17.8 | 354 | 96 |
| insert! | RSA 125 x 75 x 10 | 125 | 75 | 10 | 11 | 19.1 | 15.0 | 302 | 82 |
| insert! | RSA 125 x 75 x 8 | 125 | 75 | 8 | 11 | 15.5 | 12.2 | 247 | 68 |
| insert! | RSA 120 x 80 x12 | 120 | 80 | 12 | 11 | 22.7 | 17.8 | 323 | 114 |
| insert! | RSA 120 x 80 x 10 | 120 | 80 | 10 | 11 | 19.1 | 15.0 | 276 | 98 |
| insert! | RSA 120 x 80 x 8 | 120 | 80 | 8 | 11 | 15.5 | 12.2 | 226 | 81 |
| insert! | RSA 100 x 75 x 12 | 100 | 75 | 12 | 10 | 19.7 | 15.4 | 189 | 90 |
| insert! | RSA 100 x 75 x 10 | 100 | 75 | 10 | 10 | 16.6 | 13.0 | 162 | 78 |
| insert! | RSA 100 x 75 x 8 | 100 | 75 | 8 | 10 | 13.5 | 10.6 | 133 | 64 |
| insert! | RSA 100 x 65 x 10 | 100 | 65 | 10 | 10 | 15.6 | 12.3 | 154 | 51 |
| insert! | RSA 100 x 65 x 8 | 100 | 65 | 8 | 10 | 12.7 | 9.9 | 127 | 42 |
| insert! | RSA 100 x 65 x 7 | 100 | 65 | 7 | 10 | 11.2 | 8.8 | 113 | 38 |
| insert! | RSA 100 x 50 x 8 | 100 | 50 | 8 | 8 | 11.4 | 9.0 | 116 | 19.7 |
| insert! | RSA 100 x 50 x 6 | 100 | 50 | 6 | 8 | 8.71 | 6.8 | 90 | 15.4 |
| insert! | RSA 80 x 60 x 7 | 80 | 60 | 7 | 8 | 9.38 | 7.4 | 59 | 28 |
| insert! | RSA 80 x 40 x 8 | 80 | 40 | 8 | 7 | 9.01 | 7.1 | 58 | 9.6 |
| insert! | RSA 80 x 40 x 6 | 80 | 40 | 6 | 7 | 6.89 | 5.4 | 45 | 7.6 |
| insert! | RSA 75 x 50 x 8 | 75 | 50 | 8 | 7 | 9.41 | 7.4 | 52 | 18.4 |
| insert! | RSA 75 x 50 x 6 | 75 | 50 | 6 | 7 | 7.19 | 5.7 | 41 | 14.4 |
| insert! | RSA 70 x 50 x 6 | 75 | 50 | 6 | 7 | 6.89 | 5.4 | 33 | 14.2 |
| insert! | RSA 65 x 50 x 5 | 65 | 50 | 5 | 6 | 5.54 | 4.4 | 23 | 11.9 |
| insert! | RSA 60 x 40 x 6 | 60 | 40 | 6 | 6 | 5.68 | 4.5 | 20 | 7.1 |
| insert! | RSA 60 x 40 x 5 | 60 | 40 | 5 | 6 | 4.79 | 3.8 | 17.2 | 6.1 |
| insert! | RSA 60 x 30 x 5 | 60 | 30 | 5 | 6 | 4.29 | 3.4 | 15.6 | 2.6 |
| insert! | RSA 50 x 30 x 5 | 50 | 30 | 5 | 5 | 3.78 | 3.0 | 9.4 | 2.5 |
| insert! | RSA 45 x 30 x 4 | 45 | 30 | 0.5 | 4.5 | 2.86 | 2.3 | 5.8 | 2.0 |
| insert! | RSA 40 x 25 x 4 | 40 | 25 | 4 | 4 | 2.46 | 1.9 | 3.9 | 1.2 |
| insert! | RSA 40 x 20 x 4 | 40 | 20 | 4 | 4 | 2.26 | 1.8 | 3.6 | 0.60 |
| insert! | RSA 30 x 20 x 4 | 30 | 20 | 4 | 4 | 1.86 | 1.5 | 1.6 | 0.55 |
| insert! | RSA 30 x 20 x 3 | 30 | 20 | 3 | 4 | 1.43 | 1.1 | 1.3 | 0.44 |
| custom! | |||||||||
Edit:
undo -
redo
Color:
change color!
View:
iso -
top -
front -
right -
left -
back -
bottom
Make Component:
Rotate Object(s):
degrees around
red,
green or
blue
move/copy!
no. copies
red
green
blue
with multiple copies.
move!
New! Change Insertion Point
red
green
blue
- Start position
red
green
blue
- End position
insert!
insert!
red (size)
green (size)
blue (vertical position)
insert!
red (horizontal position)
green (size)
blue (vertical size)
insert!
red (size)
green (horizontal position)
Insert Box: - add a box
insert!
red (width)
green (depth)
blue (height)
insert!
name
url
10 3 21
It's FREE and
it's FUN!
Download
engineeringtoolbox.rb
Exit and reload SketchUp!
or
(Mac)
(Mac users look here!)
add components to the
groups!
on Mac computers.
