Construction channels - dimensions and static parameters..
Aluminum Association Standard Channels -
Dimensions and Static parameters - Imperial Units
BS 4 Rolled Steel Channels -
BS 4: 1993 - Dimensions and Static parameters - Metric Units
C - American Standard Channels -
ISMC Indian Channels -
UK PFC - British U-profile with Parallel Flanges -
UPE - Channels with Parallel Flanges -
UPN - European Standard Channels -
Dimensions and Static parameters - tapered flanges - Metric Units
Edit:
undo -
redo
Color:
change color!
View:
iso -
top -
front -
right -
left -
back -
bottom
Make Component:
Rotate Object(s):
degrees around
red,
green or
blue
move/copy!
no. copies
red
green
blue
with multiple copies.
move!
New! Change Insertion Point
red
green
blue
- Start position
red
green
blue
- End position
insert!
insert!
red (size)
green (size)
blue (vertical position)
insert!
red (horizontal position)
green (size)
blue (vertical size)
insert!
red (size)
green (horizontal position)
Insert Box: - add a box
insert!
red (width)
green (depth)
blue (height)
insert!
name
url
12 2 9
It's FREE and
it's FUN!
Note! The SketchUp plugins directory is located somewhere similar to "c:\Program files\Google\Google SketchUp X\Plugins" (Windows)
or
"Macintosh HD > Library > Application Support > Google SketchUp X > SketchUp > plugins"
(Mac)
(Mac users look here!)
(X is the SketchUp version on your computer)
SketchUp works with Linux under Wine. Since the engineeringtoolbox plug-in uses the SketchUp Webdialog feature implemented only for IE on Windows and Safari on Mac - IE on Wine is probably required. This is not tested and feedback is wanted.
add components to the
groups!
on Mac computers.
