Dimensions and Static parameters - Imperial Units
| Designation | Depth | Width | Thickness Web | Thickness Flange | Sectional Area | Weight | Moment of Inertia - Ix | Moment of Inertia - Iy | Section of Modulus - Wx | Section of Modulus - Wy | |
| in | in | in | in | in**2 | lb/ft | in**4 | in**4 | in**3 | in**3 | ||
| insert! | C 15 x 50 | 15 | 3.716 | 0.716 | 0.650 | 14.7 | 50 | 404 | 11 | 53.8 | 3.78 |
| insert! | C 15 x 40 | 15 | 3.520 | 0.520 | 0.650 | 11.8 | 40 | 349 | 9.23 | 46.5 | 3.37 |
| insert! | C 15 x 33.9 | 15 | 3.400 | 0.400 | 0.650 | 9.96 | 33.9 | 315 | 8.13 | 42.0 | 3.11 |
| insert! | C 12 x 30 | 12 | 3.170 | 0.510 | 0.501 | 8.82 | 30 | 162 | 5.14 | 27.0 | 2.06 |
| insert! | C 12 x 25 | 12 | 3.047 | 0.387 | 0.501 | 7.35 | 25 | 144 | 4.47 | 24.1 | 1.88 |
| insert! | C 12 x 20.7 | 12 | 2.942 | 0.282 | 0.501 | 6.09 | 20.7 | 129 | 3.88 | 21.5 | 1.73 |
| insert! | C 10 x 30 | 10 | 3.033 | 0.673 | 0.436 | 8.82 | 30 | 103 | 3.94 | 20.7 | 1.65 |
| insert! | C 10 x 25 | 10 | 2.886 | 0.526 | 0.436 | 7.35 | 25 | 91.2 | 3.36 | 18.2 | 1.48 |
| insert! | C 10 x 20 | 10 | 2.739 | 0.379 | 0.436 | 5.88 | 20 | 78.9 | 2.81 | 15.8 | 1.32 |
| insert! | C 10 x 15.3 | 10 | 2.600 | 0.240 | 0.436 | 4.49 | 15.3 | 67.4 | 2.28 | 13.5 | 1.16 |
| insert! | C 9 x 20 | 9 | 2.648 | 0.448 | 0.413 | 5.88 | 20 | 60.9 | 2.42 | 13.5 | 1.17 |
| insert! | C 9 x 15 | 9 | 2.485 | 0.285 | 0.413 | 4.41 | 15 | 51.0 | 1.93 | 11.3 | 1.01 |
| insert! | C 9 x 13.4 | 9 | 2.433 | 0.233 | 0.413 | 3.94 | 13.4 | 47.9 | 1.76 | 10.6 | 0.962 |
| insert! | C 8 x 18.75 | 8 | 2.527 | 0.487 | 0.390 | 5.51 | 18.75 | 44.0 | 1.98 | 11.0 | 1.01 |
| insert! | C 8 x 13.75 | 8 | 2.343 | 0.303 | 0.390 | 4.04 | 13.75 | 36.1 | 1.53 | 9.03 | 0.854 |
| insert! | C 8 x 11.5 | 8 | 2.260 | 0.220 | 0.390 | 3.38 | 11.5 | 32.6 | 1.32 | 8.14 | 0.781 |
| insert! | C 7 x 14.75 | 7 | 2.299 | 0.419 | 0.366 | 4.33 | 14.75 | 27.2 | 1.38 | 7.78 | 0.779 |
| insert! | C 7 x 12.25 | 7 | 2.194 | 0.314 | 0.366 | 3.6 | 12.25 | 24.2 | 1.17 | 6.93 | 0.703 |
| insert! | C 7 x 9.8 | 7 | 2.090 | 0.210 | 0.366 | 2.87 | 9.8 | 21.3 | 0.968 | 6.08 | 0.625 |
| insert! | C 6 x 13 | 6 | 2.157 | 0.437 | 0.343 | 3.83 | 13 | 17.4 | 1.05 | 5.80 | 0.642 |
| insert! | C 6 x 10.5 | 6 | 2.034 | 0.314 | 0.343 | 3.09 | 10.5 | 15.2 | 0.866 | 5.06 | 0.564 |
| insert! | C 6 x 8.2 | 6 | 1.920 | 0.200 | 0.343 | 2.40 | 8.2 | 13.1 | 0.693 | 4.38 | 0.492 |
| insert! | C 5 x 9 | 5 | 1.885 | 0.325 | 0.320 | 2.64 | 9 | 8.90 | 0.632 | 3.56 | 0.450 |
| insert! | C 5 x 6.7 | 5 | 1.750 | 0.190 | 0.320 | 1.97 | 6.7 | 7.49 | 0.479 | 3.00 | 0.378 |
| insert! | C 4 x 7.25 | 4 | 1.721 | 0.321 | 0.296 | 2.13 | 7.25 | 4.59 | 0.433 | 2.29 | 0.343 |
| insert! | C 4 x 5.4 | 4 | 1.584 | 0.184 | 0.296 | 1.59 | 5.4 | 3.85 | 0.319 | 1.93 | 0.283 |
| insert! | C 3 x 6 | 3 | 1.596 | 0.356 | 0.273 | 1.76 | 6 | 2.07 | 0.305 | 1.38 | 0.268 |
| insert! | C 3 x 5 | 3 | 1.498 | 0.258 | 0.273 | 1.47 | 5 | 1.85 | 0.247 | 1.24 | 0.233 |
| insert! | C 3 x 4.1 | 3 | 1.410 | 0.170 | 0.273 | 1.21 | 4.1 | 1.66 | 0.197 | 1.10 | 0.202 |
| custom! | |||||||||||
Edit:
undo -
redo
Color:
change color!
View:
iso -
top -
front -
right -
left -
back -
bottom
Make Component:
Rotate Object(s):
degrees around
red,
green or
blue
move/copy!
no. copies
red
green
blue
with multiple copies.
move!
New! Change Insertion Point
red
green
blue
- Start position
red
green
blue
- End position
insert!
insert!
red (size)
green (size)
blue (vertical position)
insert!
red (horizontal position)
green (size)
blue (vertical size)
insert!
red (size)
green (horizontal position)
Insert Box: - add a box
insert!
red (width)
green (depth)
blue (height)
insert!
name
url
9 11 21
It's FREE and
it's FUN!
Download
engineeringtoolbox.rb
Exit and reload SketchUp!
or
(Mac)
(Mac users look here!)
add components to the
groups!
on Mac computers.
